http://img.photobucket.com/albums/v719/bennyboyt/untitled-4.jpg
ive circled the problem, any ideas on what causes this?
thanks in advance
From the looks of it , and without knowing the source "hint" , then its video bitrate is to low .
Too low a bitrate, simple as that.
What you are seeing is an effect called posterisation. Essentially, it results from not enough bits being allocated to the video so that the codec can resolve gradual transitions in colour such as skin tones properly. So instead of that subtle weave of colour that real human skin looks like in film, you get a series of abrupt, uneven steps.
The likely culprit is having tried to put too much video onto the one disc. Posterisation effects generally happen when trying to fit more than two hours of footage onto a single layer, although this can also vary depending on the amount of motion in the footage. Without knowing what your source is, however, that's as much insight as I can offer."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
thanks for the quick replys guys, so nothing i can do about it really... thanks anyways
You can also get posterisation from running your desktop in 16 bit colour mode. Also, some version of virtualdub set the preview to 16 bit colour mode by default. However, looking at the overall poor quality of the video, over compression is by far the most likely cause in this case.
Read my blog here.
The solution depends on a lot of different things. The oft-repeated golden rule here is to give as much information as you think an expert needs to discern the nature of the problem, then give some more.
If, as guns1inger has suggested, you are watching the DVD on a desktop in 16-bit colour mode, then it is possible simply switching to 32-bit colour will fix the problem.
If these are original, store-bought DVDs, then unfortunately you are ought of luck, and your best recourse is to complain loudly to the distributor (and in public forums where other potential buyers might see it).
If these are copies you have made from another source, especially an original DVD, then your basic option is to try again with less compression. Assuming the posterisation is not already present in the source, of course."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
Correcting colours in CS4
By sterankin in forum EditingReplies: 2Last Post: 6th Sep 2011, 05:24 -
Camcorder changes original colours
By marklewis in forum Capturing and VCRReplies: 2Last Post: 31st Mar 2009, 12:40 -
Massive problem with DVD playback, weird colours/green bars/other
By Mr. SoAndSo in forum Newbie / General discussionsReplies: 4Last Post: 16th Nov 2008, 18:37 -
Colours looks bad with DVDs on my tv output
By Nitre in forum Software PlayingReplies: 3Last Post: 31st Dec 2007, 10:48 -
funny colours in quicktime
By Shaorin in forum Newbie / General discussionsReplies: 3Last Post: 30th May 2007, 18:17
