I have a particular MKV File that I am in the process of converting to DVD.
Normally, with MKVs that contain a video that are H264, I just use AllToAVI to convert it because I have never been able to get to work with CCE.
I decided to come on this forum and try to find out why I can never get CCE to accept and Avisynth Script with an input file of H264. I wrote a program in
VB.Net that streamlined all of my conversions such as OGM->AVI, MKV->AVI, but I cannot use this tool when I am dealing with H264.
Here are the specs for the MKV, based on the person who made it:
DVD 720x480
x264
AC3 5
Here is the command I used with Mencoder to copy the video into an AVI Container:
<MENCODER>
mencoder "C:\input.mkv" -o "C:\output.avi" -aid 0 -mc 0 -ovc copy -oac mp3lame -lameopts cbr:br=128:mode=0
</MENCODER>
Now, I used FitCD to generate my AviSynth Script:
Here is the actual AviSynth Script FitCD generated
<AVISYNTH>
# -= AviSynth v2.5.7.0 script by FitCD v1.2.8 =-
AVISource("C:\output.avi")
LanczosResize(704,480,0,1,720,478)
AddBorders(8,0,8,0)
#Trim(0,129249).FadeOut(150)
ConvertToYUY2() # For VirtualDub or CCE
</AVISYNTH>
Here is what CCE says when I try to drag the AviSynth Script into it:
Here is what VirtualDubMod says when I try to drag the AviSynth Script into it:
Now, I tried changing "AVISource" to "DirectShowSource", but to no avail.
Any help would be greatly appreciated it. I will go ahead and use AllToAVI and also continue to search for the answers I am seeking in this post.
Versions of Software I used:
cccp - Not sure what version, but I know I downloaded my most recent version about 2-3 months ago
Windows XP
CCE SP Ver 2.70.02.10
AviSynth 2.5
FitCD 1.2.8
VirtualModDub 1.5.10.2
Results 1 to 19 of 19
Can you open output.avi in VirtualDub without using AviSynth?
Buy My Books -
The 1 is illegal with YV12 video (all odd values are). It might work if you ConvertToYUY2() first.
Also note that AVISource() requires a VFW h.264 decoder (I'm pretty sure CCCP doesnt include one). Try DirectShowSource() instead. -
Thanks for the reply Jagabo.Originally Posted by jagabo
How would I get a DirectShowSource? Does that come with CCCP?
When I changed it to DirectShowSource, CCE accepts it but I know something is wrong because the CCE Duration is wrong. It is specifying 10 minutes and this is an entire movie. -
Buy My Books -
Thanks for the posts fellas.
Also, the AVI will play in Mplayer, but it seems to have trouble playing WMP.
Also, like usual, AllToAvi handled it fine. The Avi it rendered was opened in FitCD, and the AVS file was accepted without incident in CCE.
That is what is so confusing. AllToAvi uses Mencoder and all of my Mencoder command lines always failed when the input was H264.
I am starting from scratch and going over the mencoder guide. I never really understood Mencoder, just got a sample command line from 45Tripps one day and just rolled with that on all my files.
So I am sure I will have more questions for you all. -
I recently used something like this (with Haali Media Splitter and ffdshow installed) for opening an .mkv with h264/ac3:
DirectShowSource("video.mkv", fps=23.976, audio=false)
(fps=... should be the actual value) -
Thanks for the reply fellas.
Here is the script I used:
<script>
DirectShowSource("C:\input.mkv", fps=23.976, audio=false)
LanczosResize(704,480) <-----you said a 1 was an invalid value so I just took all the numbers to the right of 480 off
AddBorders(8,0,8,0)
ConvertToYUY2()
</script>
Still got the same error when I tried to open it up in CCE. To note, all the little icons did pop up in the systems tray when I dragged the script into CCE, so I know the Haali Splitter and FFDshow is installed correctly.
I already have the file on DVD, via AllToAvi, so I think I am going to concede defeat with the method we have been discussing. -
jagabo wrote:
It seems that's only what should be actually happening. For example,
now and then I create some slideshow movies with Avisynth's ImageSource.
When I use non-PNG pictures, TMPGEnc accepts the scripts, but when I try
to use PNGs, TMPGEnc displays an error message --- BTW, TMPGEnc does not
accept PNG files as a valid video input. I suppose something similar happens
to CCE with respect to H264 sources. As a "desperation move", I suggest trying
to use VirtualDub to frameserve the Avisynth script into CCE.
I just tried serving a bunch of PNG files from AviSynth to TMPGEnc Plus and had no problems. I suspect you just had a colorspace issue. Try adding ConvertToRGB24() or ConvertToYUY2().Originally Posted by Midzuki
jagabo is correct. AviSynth presents only uncompressed frames. I suspect the difficulties you encountered with TMPGEnc and png pictures were colorspace issues or something similar. This is a case of AviSynth not understanding the video and therefore not being able to render the frames.Originally Posted by Midzuki
Try forcing the avc1 codec in the AviSource command with output.avi. Alternatively try OpenDMLSource with avc1 forced."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
Probably it was something related to my personal version of the
"codec hell"
I was going to post a picture of the error message
I had referred to, but now, much to my surprise, TMPGEnc did accept
a PNG-ed ImageSource without a complaint
Last week I uninstalled
MainConcept, which I used very rarely --- this might explain the miracle.
And as I said before, those error messages, related to the
Developer's Image Library (DevIL), were started not by Avisynth, but by
TMPGEnc Plus --- VirtualDub for example never had a problem at encoding
PNG ImageSource scripts, and this the reason why I suggested the double-frameserving.
Avisynth MPEG2 to h264 Program Suggestions?
By VideoFanatic in forum RestorationReplies: 2Last Post: 14th Feb 2012, 19:33 -
Questions about H264 encoding?
By Mr.Teflondon187 in forum Video ConversionReplies: 3Last Post: 21st May 2010, 03:02 -
H264/AVC (.TS) gets outsync when using VDub and AviSynth
By x92 in forum DVB / IPTVReplies: 2Last Post: 30th Aug 2009, 23:03 -
Loading H264 onto avisynth script
By carlmart in forum Blu-ray RippingReplies: 21Last Post: 10th May 2009, 14:22 -
Changing FPS of .h264 loaded in MeGUI w/Avisynth
By karpodiem in forum Video ConversionReplies: 8Last Post: 6th Apr 2009, 11:27
