You have all been GREAT in the past and I am all set with DVD...but this newfangled MP3/MP4 stuff has me at my wits end. Have a holiday gift for my wife (Sony MP3 player) that allows video in MP4 formats encoded in H.264/AVC and AAC.
I have a bunch of home movies in .avi and .mpg format. They didn't provide a conversion tool and I downloded a couple but still get an error message on the format.
Anyone know of a specific tool that will conver to this type of MP4?
THANKS!!!
Hi,
Try WinFF and use the *iPod Linux* presets (they are good for general H.264 use as well) The only thing to check out is the resolutions the device supports, the iPod presets are set for 640xXXX depending on the aspect ratio of your source, but you can easily enter your own resolutions if needed. -
No luck
Can't figure t his out! You think they'd provide conversion software UGH!
Hi Again,
No luck with WinFF? That's weird, are these files to be converted some standard format like DVD,VCD,DivX? A lot of people like SUPER, I'm no a big fan of it's heavy footprint on the system and it doesn't always play nice with other applications, but it seems to be a decent "Swiss Army Knife" encoder. If you could give us a bit more info on what your source files are, and what specs SONY has for the converted files it'd help narrow things down. -
Here is what I know. My source files are usually MPEG-1/2 or AVI...home movies mostly
The sony manual says :
VIDEO AVC(H.264/AVC) Baselie Profile Bit rate max=768
MPEG-4 Simple profile, bit rate max 2500 KBPS
Frame rate max 30fps
Resolution max QVGA 320x240
Does that help?
THANKS for taking the time -
OK,
The specs you're saying are like the old iPod specs, the ones in WinFF are for newer iPods so that's why they won't work. So in WinFF you'll have to make a custom preset, or try SUPER and enter the specs in when you set up your conversion. Another great choice is Nero Recode, it's not free but I think there is a 30 day free trial and it will enable you to go direct from DVD to your final file. It's fairly intuitive and gives good quality results. -
Or try with MeGui or,
https://www.videohelp.com/tools/Videora_iPod_Converter" Who needs Google, my wife knows everything"
Trouble with MKV to MP4 Video conversions for Ipod
By Shisehise in forum Video ConversionReplies: 3Last Post: 10th Jan 2012, 01:17 -
Problems with conversions
By dkritso in forum Newbie / General discussionsReplies: 4Last Post: 28th Jun 2010, 01:18 -
mpeg-ts and .ts conversions
By nirbhayn in forum DVB / IPTVReplies: 3Last Post: 30th Aug 2009, 18:00 -
Best conversions for dvd
By atvmxr in forum Video ConversionReplies: 5Last Post: 22nd Apr 2008, 09:47 -
What is the difference between these conversions?
By neo_74 in forum AudioReplies: 2Last Post: 3rd Jan 2008, 19:42
