I have a Philips DVD player that can play DivX files, so I made a disc with some avi files (with the divx compression format), but when I play it on my player, it seems to cut off the bottom and top a little bit. The resolution of the videos are 640 x 480, do I need to resize the files or am I doing something else wrong?
There is nothing wrong. Televisions are designed to overscan the image. You have never seen the outer ~5 percent of the picture on anything you have ever watched. You've just never noticed before because you didn't have an external reference.
This question usually comes up because someone has some fan sub anime and can't see the subtitles (pros know not to put the sub at the very edge of the frame). If that's the case you will have to reencode the video with a black border around the edges so that the black border is hidden by the overscan, not the picture. -
Thanks for the answer jagabo. Yeah that's exactly the problem, I can only see about half of the subtitles. Do all TVs do this or just old ones?
And what program would you recommend I use to put a black border around it? -
Pretty much all TVs overscan. The amount varies from model to model, and on CRTs it varies as TVs warm up or age. There are a few HDTVs with no-overscan options. Samsung's current LCD HDTVs for instance.
You can use VirtualDub to add borders and reencode. The best results will come from using AviSynth (to resize and add borders) and VirtualDub (to encode) together. Resize the 640x480 frame to about 576x432 then add borders (32 left and right, 24 top and bottom) to bring the size back up to 640x480.
There are many discussions and guides on this subject. Search for overscan and subs.
DVD Player that plays Divx (.avi) and (.mp4) files ?
By keith knip in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 14:12 -
How do convert Divx files to play on my DVD player?
By Solehawk in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:37 -
DVD player can't read large DIVX files
By Alistair George in forum Authoring (DVD)Replies: 14Last Post: 27th Jan 2009, 18:16 -
Best Divx Ultra DVD Player with Full file Names for MP3 and DivX Files
By MCalca1706 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 12th Nov 2008, 12:00 -
Any DVD player that will play divx files larger then 2GB?
By David9799 in forum DVD & Blu-ray PlayersReplies: 27Last Post: 9th Nov 2007, 10:53
