I have two copies of the same movie. One is a standard 2D version with an English audio track. The other is a field-sequential 3D version with a Spanish audio track. What I need to be able to do is remove the Spanish audio track from the 3D version and replace it with the English track from the 2D version.
One hitch that might make a difference is that the video file cannot be remastered. If you are unfamiliar with field-sequential 3D... A field-sequential 3D video signal is a normal video signal which has been specially recorded with left and right images stored on the even and odd fields of the video signal.
I have tried to create a DVD from field-sequential mpeg files and in the process of recoding the video, the "flickering" effect was inadvertently stripped out and I was left with a 2D version of what I had started with.
The software that I currently have installed is as follows: Nero Recode, NeroVision Express, DVD Cloner, DVDShrink, TMPGEnc, VirtualDub. I will install anything else that I need to get this done at your suggestion.
I would really like to get this done as soon as possible, since the video that I am trying to edit is a Christmas show.
Thanks, in advance....
Hi-
These are both DVDs? And they're both exactly the same length so you really can substitute one audio track for the other?
If so, then demux them both (PGCDemux, making sure to check the "Demux video stream" box). Switch the audio tracks. Remux (Muxman). Replace the old DVD with the original audio with the new DVD with the new audio using the replace button in VobBlanker (if there are menus or anything else you want to keep).
No reencoding needed. All programs are freeware. -
Take a look at this excellent guide:
https://forum.videohelp.com/topic338721.html
Look at "Method 2" and note that you don't really need to worry about the subtitle stuff. The basic procedure of using PGCDemux, Muxman and VobBlanker as manono talks about is here with a few photos to help you. -
Thank you for your replies...
I forgot to mention, the copy with the English track is an AVI. As for EXACT length, I will have to check. I figured I could trim or pad the track if necessary to make the length correct... ? -
So, demux the audio, and if it's not DVD compliant (MP3, for example), convert it to AC3 audio. Then follow my instructions.I forgot to mention, the copy with the English track is an AVI.
Perhaps not. If they're not the same length, it may be more complicated than that. They might have different framerates (one from a PAL source and the other from an NTSC source), or if both of the same format, all kinds of other things could account for differing lengths. Just hope they're the same length, of if not, that your idea of cutting audio or adding silence works.I figured I could trim or pad the track if necessary to make the length correct... ? -
I played the 3d version on the dvd player and the English audio track on the computer, just to watch it, and it's not going to work. Twice I had to pause and unpause the audio source to resync the audio and video... Not to mention the start points weren't the same.
At least I got to watch it. Thanks anyway, guys....
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
Making a dvd with an english track from a mkv file that has both japanese and english
By andyjc in forum MacReplies: 0Last Post: 12th Feb 2010, 10:41 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 13:16 -
Forcing English as the audio track to choose while playing mkv
By Wolverene in forum AudioReplies: 0Last Post: 30th Nov 2007, 11:35 -
question about getting English audio track in DVD player settings
By jimdagys in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Nov 2007, 10:05
