    Dec 2007
    I downloaded DVDflick and succesfully created a DVD that plays on a home dvd (unsuccesfully tried 2 weeks in nero 7)
    I only have one mpeg2 file with the audio in the mpeg. after burning in DVD flick I can only get it to autorun when inserted in dvd player. I want to add a background picture and a play button, can it be done in DVD flick or do I need another program and if I do need another program can I add it to my working movie I made with DVD flick.
    I hope my question is clear and posted in the right place
    Thanks in advance
    Randy
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    From the DVDFlick version history:
    Version 1.3.0.0
    Download from http://www.dvdflick.net/forums/viewtopic.php?t=534
    After a good while of work the 1.3.0.0 beta is finally here!
    The main changes are:
    - Ability to generate menus based on templates. Only one template is included at the moment.
    So, you should be able to create a DVD with menu using only DVDFlick. IAFICS, this is a new feature of v 1.3.0.0
    OTOH, I never understood the need for a menu on a one title disk...
    /Mats
