Using ProGold I can add say 19 slides to a project. I'd like to, within ProGold, have text added to the picture as 0001, 0002, etc. so that each can be identified to the person viewing the video.
Any ideas if this can be done?
On the timeline at the bottom of the screen double click on the slide you want to add text to then select Caption from the options on the left hand side.
You can now add text to the picture
What I can't do is get it to add text to ALL the slides (either constant or based on file name) which is a shame
Hope this helps -
Thanks, I just fouind teh macro option to add a whole realm of text to a slide. . . its great!
I cant do 1, 2, 3, ... unless I avoid any blank slides (since they count as one of course).
I got it to add to ALL, by default. Maybe the version. Using GLOBAL!
Thanks !
Transfer 35mm slides to DVD
By btruff in forum Newbie / General discussionsReplies: 13Last Post: 15th Apr 2017, 19:55 -
ffmpeg Number of stream maps must match number of output streams
By tmiller_15 in forum Blu-ray RippingReplies: 1Last Post: 13th Nov 2010, 07:20 -
Quality of slides
By marklewis in forum Capturing and VCRReplies: 2Last Post: 2nd Aug 2010, 21:43 -
Scanning 35mm slides?
By videobread in forum ComputerReplies: 1Last Post: 7th Sep 2007, 12:45 -
How to capture 35mm slides
By avz10 in forum Off topicReplies: 11Last Post: 29th Jun 2007, 19:52
