I'm using NeroVision to create a menu that must have 18 chapters. BUT, it won't allow me to do more than 15. It's important to me, in this project, to get all chapters on one screen.
Does anyone know of a freeware DVD maker I can use as an alternate that does this? Any info is appreciated. Thanks!
AnonymousGuest
https://www.videohelp.com/tools?listuser=&orderby=Type&s=2#2
Of these, try:
DVDAuthorgui
GUI for dvdauthor
TMPGEnc DVD Author - fully workng 30 day trialThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
There is a limit to the number of buttons you can have on a menu. For widescreen menus it is 18. For fullscreen menus it is higher (36 ?). If you have a next, previous and main button, then add 15 chapters, you have reached your limit. This is set in the DVD spec.
You need to either use fullscreen menus, or split them upRead my blog here.
Hunh guns1inger -- I've made many menus with 32 chapter buttons (and 4 buttons for intra menu nav) widescreen
Where is it set in the spec? -
Menus designed as 4:3 only can have up to 36 buttons (which is your 32 + 4).
Menus designed to works as both 16:9 and 4:3 P&S can have up to 18 buttons, and menus designed to work in 16:9, 4L3 P&S and 4:3 letterbox can have up to 12 buttons per page.
Most authoring tools will only author either 4:3 only, or 16:9/4:3 P&S, and so have only the 36 and 18 button limits.Read my blog here.
Just created a chapter menu in each aspect (28 buttons per page --24 chapter buttons) in TitleWriter (4.64 Beta Unreleased) works fine all players
Perhaps another of those specs that means nothing (I use the 36 limit in all cases)
Of course the buttons/thumbnails are rather tiny
Oops -- Its creating 4:3 menus in this case -- My Bad -- but of course it still works fine with 16:9 vts Movies -
There is nothing to stop an authoring tool creating 4:3 menus that link to 16:9 titles. Many commercial discs use this design either because they use a standard template (Paramount) or find it is more compatible with the way (predominantly US) audiences have their kit set up. Many low-end authoring tools create 4:3 menus only simply because it is easier to handle a single aspect ratio.
Read my blog here.
AnonymousGuest
That's alright. I decided this project works fine if I split the chapter listing over two menus.
Thanks for your help!
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Newbie question: menu and chapters
By cheerful in forum Authoring (Blu-ray)Replies: 0Last Post: 20th Dec 2010, 00:17 -
Without Menu, but with Chapters...
By video_enthusiast07 in forum Authoring (DVD)Replies: 10Last Post: 13th Jul 2009, 10:22 -
DVD with no menu and just chapters
By marshyman in forum Newbie / General discussionsReplies: 3Last Post: 8th Jun 2007, 18:36 -
PAL to NTSC, Menu, Chapters
By heretic754 in forum Authoring (DVD)Replies: 6Last Post: 4th Jun 2007, 14:46
