It sounds like Megui dropped frames from the evo files that is why you having this problem.I used megui twice and I had some similar problem.The final product you looking for is bluray on dvd right?Originally Posted by zerocoool
Results 91 to 114 of 114
MEL15
Member
Post Posted: Jan 03, 2008 23:13 Posts Comp View users profile Send private message Reply with quote
zerocoool wrote:
Post Posted: Jan 03, 2008 22:41 Posts Comp View users profile Send private message Reply with quote
zerocoool wrote:
mel15 i'm trying what you suggested i'm up to -10000 is this okay what the best thing to convert audio with i use eac3to with sonic because to use nero i believeyou need the hddvd plugin.
Hi -10000 seems a little steep I would start with -4000 use eac3to with sonic see what happens....let me know
mel i used -4000 with eac3to with sonic if i get the first part to match then the rest is out of sync
actually i'm trying to make a mkv file with 1280x720p for my ps3 but if you have a way to make it bluray at these settings that would be cool yes it would have to be on a 1 dvd disc -
Squeezing 21 gig of hd on 1 dvd will kill the picture quality.I used 2 dvd+dl for mine and picture quality same as hd original.Originally Posted by zerocoool
Open evodemux drop first evo file remove all except vc1 file and first audio file,check continue with next evo under options.Now you'll have the complete movie.Open Dvtool split evo file in half.Open ts remux drop first evo check bluray.To the same with second evo.you will have to bluray folders ready to burn.Once you done with that let me know I wil tell you how to burn to disk.Do you have nero? If you do what version..........Get to work and good luck.One more thing evodemux under options extensions, video evo audio ddp not dd+.Originally Posted by zerocoool
MEL15
Member
Post Posted: Jan 04, 2008 00:25 Posts Comp View users profile Send private message Reply with quote
zerocoool wrote:
well mel how do you do 2 dl split would be interested in trying it
mel15 i made it to dvtool and am currently splitting the file but if i split it in half won't each part be too big. and i do thankyou for your help. -
Does anyone in this thread know how to determine the correct Blu-Ray pgc? In other words, which m2ts file(s) to choose to get the full movie?
ultraman36
Member
Post Posted: Jan 04, 2008 09:07 Posts Comp View users profile Send private message Reply with quote
Hey quality wise what settings do you use when using megui? im at work so i cant open the program but there are a bunch of options past the cropping feature
ultraman when i did mine with megui i set the qaulity to aegoodquality and set the left the codec atx264 file format mp4 under config i made the bitrate 4500 but if you want to put it on one dvd i'd use 4000 i didn't do the audio with mine i did it seperate but could not get the video and audio to matchup afterwards . if you use the avisynth script creator you can crop it down i did mine at 1280x720 and the picture looked great on my monitor. -
Ok im gonna try convertxtodvd and see how that works. i dont want to keep a 25 gig movie on my tvix i want as best quality as i can get but maybe the size of a dual layer disk
ultraman if you use convertxtodvd i think it only does 720x480 but i could be wrong
crap when i try it ill double check and let you know what size it made it
You could split in 3 parts or 4 if you like to use dvd-r,its up to you.Originally Posted by zerocoool
There's 2 big m2ts files those are the files you want.Originally Posted by Lovepeaceguru
mel 15 i'd like to use two dvd+rdl but when i split the files it gives me two files of 12.5 gigs how do you fit them on 2 discs or did you have to use 3 discs also would like to know how to burn with nero 8.2.8.0 does it go like this use udf iso and set it to udf2.5 then add the bdmv and certificate file over.
I forgot transformers its a long movie I split it in 3, sorry my mistake.As far as burning use nero burning rom,choose dvd-rom use manual setting under udf and set for 2.5.choose new, and drag bdmv and certificate on the left side,press burn.when you done, use ps3 it will show as a avchd file.Or use bluray player.Originally Posted by zerocoool
Hi do you have a bluray player besides ps3 to tested on,or a friend who has one .It plays fine on mine .You did everything fine.Let me knowOriginally Posted by zerocoool
sorry mel just have the ps3 i did burn it on a sony dl i wander if it would work better with verbatim dl am going to try it again with verbatim but been real busy with work but will let you know
I understand take your time,just let me know we all have a job.Originally Posted by zerocoool
Ok i wound up running a dual boot with xp and vista and am using xp to encode. This is what ive done but the majority of it is the same
1) Evodemux the audio and use eac3to to get an ac3 file
2) use graphedit and used Halli splitter then the wmv dmo and saved the graph as video.grf
3) created an avs script with this
DirectShowSource("video.grf", fps=23.976, framecount=269566, audio=false)
ConvertToYV12()
4) used mediacoder http://mediacoder.sourceforge.net/
used mpg4 container/h264 codec/used bitrate for mode and set it to like 5000 this took about 8 hours to encode
5) Used mkvmerge and merged video and audio together
picture looks great and my file size is around 6 gigs as opposed to 24 gigs. The audio is off by milliseconds but im to tired to play with it will try tommorrow then put it in my tvix and see how the whole thing plays -
Hi
i think im having the same proble as you zerocoool
I am converting a hddvd rip "doom" i have converted it from a .evo to an mp4 file,then used eac3 to extract the audio then muxed them together the audio is off by bout 8 sec.
Iv played the muxed video and the .evo file together at the same time in seperate media players and i can see where the muxed file video lags behind,
to watch the video you wouldnt even notice it is missing video it seems to drop frames where the word "UNIVERSAL" is displayed for a few seconds at the start of the video,i hope you can help,
Iv encoded it on different settings with the same result
my head is melted
cheers.
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Video Captured in HD- Converted to AVHCD- Want To Move to Blu-ray Disc
By airbourne1 in forum Authoring (Blu-ray)Replies: 2Last Post: 15th May 2010, 10:17 -
?Finally took the Blu-ray plunge. My questions, thoughts, and suggestions?
By fluxcapacitormb in forum Blu-ray RippingReplies: 4Last Post: 4th Apr 2010, 02:44 -
Blu-ray Player - Finally Someone Gets It!
By SCDVD in forum Newbie / General discussionsReplies: 10Last Post: 11th Jan 2009, 11:51 -
Finally a Reason to go Blu Ray
By Soopafresh in forum Off topicReplies: 6Last Post: 12th Oct 2008, 20:21
