Ok first off i dont have the knowledge and expertise most of you have in this area. But as of today i and converted Hd-dvd disks and Blu ray disks
Blu ray
1) Ripped to hard drive then used Tsremux (i selected the video stream and 1 audio stream{non pcm lossless} ) and remuxed together not separate
2) used elecard converter studio to open file. It played the file and shows you the audio and video data(no sync issues). I selected the format i wanted to(several to chose from hdv-1 720p, hdv-2 1080i. mpeg 4 cinema, hd dvd avc. After 3 hours the movie is converted and plays great
hd-dvd
1) ripped to hard drive and used evodemux to rebuild (not demux)
2) Nero 8 just had an update today so after the update i opened nero recode and pointed it to my file(evo) clicked add file. now it took a little while for it to analize the file but after a couple of minutes i could play the movie in the preview window. im waiting for it to finish recoding but everyhting looks good. (ps i did buy the hd-dvd option from nero so that may have helped as well
Now i know alot of you can probably do this with you eyes closed with other software but i more typing this for the people who dont understand command lines, scripts, using avisynth etc etc
Elecard converter is expensive to buy) but they have a free trial and there is a cheaper products that may work and they offer trails
Results 1 to 30 of 114
So how do you rip an HD DVD to the hard drive? I downloaded the free DVDfab for HD DVD. I already own the DVDplatinum edition. The program will not read the HD in the dvd drive. I have two, a Pioneer 110D and a NEC 2500a. Both DVD player/writers will not recognize the HD DVD. So now what?
You have to have and Hd -dvd drive not a regular dvd/burner. I have a xbox 360hd-dvd but wound up buying this
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136133
I have the free version of dvd fab hd decrypter and slysoft any dvd hd -
It's a little too pricey for me. I guess I will have to pay attention to the DVD I buy. I didn't realize I wouldn't be able to play it on my computer. I don't have an HD player only an HD monitor and TV. This is getting crazy isn't it? I think I'll wait until something more affordable comes along and all this format stuff is resolved.
if you only want to do hd-dvd then buy the xbox 360hd-dvd thats what i got firts but since i wanted to do both hd-dvds and blu ray i got the lg so now my 360 hd dvd just sits around
Why not try selling it? I bought mine online at an auction for a 100.00. Would be worth looking into if your used to selling online...... Just a thought..Originally Posted by ultraman36Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
I was trying to sell it to friends. That way i dont have to worry about shipping etc etc. I may ebay it but im trying not to cut the upc label off and send in for those 5 free dvds lol must resist temptation
Hey ultraman36,
I don't mean to change the subject on you but do you know of a way to burn Blu Ray back on to disk after ripping? Basically just copying a BD? -
Rip hddvd to hard drive. Use evodemux choose video and audio rebuild evo.Split files with dv tool (to 4.2g) Open ts remux choose evo files to remux, check bray ....remux .Burn to dvd with nero, burning rom choose dvdrom udf,click udf choose manual setting udf 2.50.open new, drag both files created by ts remux burn on to dvd and enjoy a perfect bluray 1920 1080p movie.
tommyoz read the first part of my thread blu ray was the first i mentioned. I havent had a chance to test the blu ray files in nero yet just in the Elecard app
Mel15..does your method create a disc to play in an HD or BD player?
Hey mel15 Thanks i used evo demux, then tsremux and used the blu ray setting. Then went back and used evodemux to put the audio in the eac3 format. Then from there used eac3to to conert it to an ac3 file. Opened Nero vision to make movie imported the video then audio then play it and it plays with no sync issues
Ultraman36, What did you convert the blu ray to?Originally Posted by ultraman36
Its still converting looks like it takes about 5 ish hours
Format Nero Digital avc
Profile Nero Cinema Avc
output file = 1280x720 5521 kbit/s
Audio =2 channel
pretty much i guess its their mp4 at a higher res -
Beautiful, absolutely beautiful. Exactly what I was looking for. I took an HD DVD and ripped it. Burned onto Blu Ray disc (since there are no HD DVD burners yet). Burned with IMGBurner as Megahurts suggested and it played fine as both a Blu ray and an HD DVD disc on my computer. Using Cyberlink and Nero showtime. I will be getting my Blu ray/HD DVD player soon so I'll have to wait and see. Just might bring it to a store and see.
There is no reason why it wouldn't work with copying a Blu ray disc as well. Will do that next. -
Hi scooter_nj it played on ps3 and standalone bluray player. on ps3 it show as AVCHD.........GOOD LUCKOriginally Posted by Scooter_NJ
Goin to try your way.....keep up the good workOriginally Posted by ultraman36
Im going to do a clean install today. if i knew how to use the other stuff like xport, graphedit etc etc i would do a step by step guide with detailed on each app to use but the learning curve is still a little steep so im trying to stick to a simple way. Sucks that it takes so long to encode but nothing i can do about that
ultraman36 - you mentioned that you got no audio from Nero Recode on your HD-DVD.........any progress? Or still no audio. I have the same issue.
The way I did mine no need to convert audio files i just rebuild the evo files and converted them to m2ts and it work great for me.Ps3 and samsung bray player both think its a bluray disk instead its a regular dvd-r.Originally Posted by ultraman36
Hey mel15 im not burning to a disk i need to reconvert the bigger file to a smaller file to play on my tvix 4100 the m2ts file will play but i want to down the size. dieselbolts i have audio but i have another problem. Nero seems to convert the back bars as well so my video image is smaller than it should be ie it converts the 16x9 to 4x3 including extra space. nero recode will let you crop the picture but i need to use nero vision to add the ac3 audio that wont let me crop. I just found another guide (sort of so ill try that and get back to you
I must be missing something. I have tried inserting one of the split EVO files into tsremux, but it always crashes or freezes when I do this. Burning the split files as they are will not play in my HD-DVD player.Originally Posted by MEL15
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
Video Captured in HD- Converted to AVHCD- Want To Move to Blu-ray Disc
By airbourne1 in forum Authoring (Blu-ray)Replies: 2Last Post: 15th May 2010, 10:17 -
?Finally took the Blu-ray plunge. My questions, thoughts, and suggestions?
By fluxcapacitormb in forum Blu-ray RippingReplies: 4Last Post: 4th Apr 2010, 02:44 -
Blu-ray Player - Finally Someone Gets It!
By SCDVD in forum Newbie / General discussionsReplies: 10Last Post: 11th Jan 2009, 11:51 -
Finally a Reason to go Blu Ray
By Soopafresh in forum Off topicReplies: 6Last Post: 12th Oct 2008, 20:21
