The other day my pc says that starforce drivers are not compatable with vista and since I didn't install them I removed them and now when I mount an image with alcohol 120 and try to burn it I can't or if I try to copy a dvd the program I use to copy dvds are dvdfab platinum.
Results 1 to 20 of 20
Uh oh. Don't let crap get installed in your computer...
http://en.wikipedia.org/wiki/StarForce
/Mats -
Yep! if you're using alcohol chances are it's (crap) still there..
http://www.onlinesecurity-on.com/protect.phtml?c=55" Who needs Google, my wife knows everything" -
I used the tool to remove starforce but it is still doing the same thing
Uninstall Alcohol 120 and see if you're able to use DVDFab Plat once again....
My guess is that starforce has hijacked your DVD reader/writer drivers somehow. If I understand it correctly, it works at a very deep level in the I/O system.
If nothing else helps, take your problem to http://www.star-force.com/ - they broke your computer - now they should fix it. They ought to be happy to get a chance to make up for all the flak they've taken for their game protection system.
/Mats -
It's worth a try. Like I said, they broke your computer (provided you've installed a legit starforce protected game, following directions, and that caused all this). The very least they should provide is some kind of phone support.
/Mats -
You might do a Google search for ' starforce problems '. There are a lot of unhappy people with similar problems. Hopefully if all that's said is true, maybe someone will bring a suit against them and make them rethink their programing methods. That got Sony's attention.
t_jay17, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
I looked it up and found no help at all as to how to return my pc to normal.
Unfortunately, from what I read there, the sure cure is a reinstall of Windows.
But hopefully you wil find a less drastic fix.
I'm not sure what you mean by a 'upgrade'. If you mean to a different version of Vista, say from home to premium, probably won't work. Upgrades just add features most times, not redo the OS.
You could try a 'repair' install first. That just replaces the Windows OS. It should leave most of your programs intact, at least the ones that aren't partially installed into your Windows folder.
But with any drastic action like this, back up any files, documents and other data that can't be replaced.
If it fails to cure the problem, then a repartition, reform and reinstall is a sure cure. Make sure all your motherboard drivers are available with either method, along with drivers for video and any other add on cards. -
This MS guide tells you how to do a repair install: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
You just need the OS disc and boot from it. You will also need to reinstall the updates to the OS afterwards.
And I assume you already tried using the Windows System Restore function already? It may not help, depending on where the problem is, but I would try it. -
When I tried system restore suddenly there were no restore points to use.
That doesn't surprise me. Some malware/virus/trojan programs can also block system restore. Another sign of a major problem.
Try the repair, but be prepared for a full reinstall. Vista is generally fairly tough to mess up, more so than XP, IMO. It usually warns you about installing some programs.
You might also consider getting a backup program like Acronis True Image or similar to make a backup of your system after you get it working properly so you would have a easy restore in the future.
32-bit program Micrografx on 64-bit windows vista?
By Obamargarine in forum ComputerReplies: 8Last Post: 11th Aug 2009, 18:56 -
Windows Vista: 32 bit or 64 bit?
By vid83 in forum ComputerReplies: 7Last Post: 12th Feb 2009, 03:57 -
Vista Home Premium x64 (64-Bit) vs x86 (32-Bit)
By Shibblet in forum Media Center PC / MediaCentersReplies: 8Last Post: 30th Sep 2008, 17:42 -
New PC coming with 64 bit Vista but I think its a 32bit machine...problem?
By Rudyard in forum ComputerReplies: 10Last Post: 21st Jul 2008, 18:47 -
Windows Vista 64 bit, problem
By reinnie in forum Capturing and VCRReplies: 3Last Post: 16th May 2008, 08:08
