This is a good one. Useing AnyDVD V6.3.0 and CloneDVD2 V2.9.1.2, I can't backup the movie Bourne Supremacy.
First, I get a dialog box to install Interactual Player. When I close that out, the list in CloneDVD2 only shows two empty audio entries, no video files! The disc won't play in WinDVD7 either, though it will play in a stand alone player.
Any idea what's up with this??
Results 1 to 10 of 10
Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
You might try turning off 'Auto play' for that drive. If that fails, try using DVDFab HD Decrypter to rip the DVD to your hard drive. Interactual is trying to take over, as it's designed to do when playing back on a computer.
Let me expand that to "You should never have 'Auto Play' enabled for any CD/DVD drive."Originally Posted by redwudz
http://en.wikipedia.org/wiki/InterActual_Player
Next time, they'll "forget" to tell you they are installing something in your computer.
/Mats -
DVDFab HD Decrypter just rips to a 1:1 copy on your HDD. Once there, you can further process it with other tools (to split and/or compress) or just burn it to disk.
/Mats -
That's out.
How about the full Gold or Platiumn versions?
BTW; this is a SD DVD.Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things. -
Why don't you have a look at www.dvdfab.com ?
/Mats -
I am.
Ok, I looked and had a couple of questions:
1. I assume it is a 'all in one' program as opposed to AnyDVD/CloneDVD2?
2. If so, when/where/how does it or you update the program for new copy protection schemes??
3. On the 'Split' page, when the option 'Preserve menus on Disc 2' is unchecked, I can't uncheck any of the choices for Disc 1. I'm confused about the setup and purpose of that page.Why are ones and zeros so complicated? Linear Video Editing was easier. Downloading & streaming are two different things.
Are the Jason Bourne books worth a read? I like the movies so far....
By yoda313 in forum Off topicReplies: 10Last Post: 11th Aug 2011, 18:25 -
Best music creation software (Dance/Hiphop samples Included)
By Hank Kinsley in forum Off topicReplies: 0Last Post: 30th Oct 2009, 23:50 -
I'm unable to preview videos in any video editing software
By ppeterr in forum Newbie / General discussionsReplies: 11Last Post: 3rd Oct 2009, 23:50 -
Removing Interactual from DVD backup
By iced in forum DVD RippingReplies: 4Last Post: 19th Feb 2008, 22:35 -
Unable to backup my dvd's with 740e and DVD decrypter
By sono in forum Newbie / General discussionsReplies: 12Last Post: 4th Sep 2007, 00:02
