While opening VirtualDub I get the error :
VirtulaDub has detected an improper VBR audio encoding in the source AVI file and will rewrite the audio header with standard CBR values during processing for better compatibility. This may introduce up to 0 ms of skew from the video stream. If this is unacceptable, decompress the entire audio stream to an uncompressed WAV file and recompress with a constant bitrate ancoder.(bitrate: 128.0 kbps)
what do I have to do in the virtualdub to fix it ? (I cant convert it in the TMPGEnc)
How do I decompress/compres the wav file?
Results 1 to 1 of 1
a problem with virtualdub when i try to convert mkv to avi
By romanch in forum Video ConversionReplies: 6Last Post: 24th Jun 2009, 00:41 -
Problem joining (concatenating) avi's in virtualdub
By uart in forum EditingReplies: 6Last Post: 21st Nov 2008, 16:44 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 07:53
