Hi guys, can anyone comment on the TBC capabilites (if any) of the DV2001 (firewire analog to DV device: http://www.questronix.com.au/products/dv2001.htm)?
The bottom line of this page: http://www.questronix.com.au/info/info_tbc.htm seems to suggest some capability, but it's not mentioned anywhere in the unit's specs - wondering how much it would do for me.
I've got a lot of old EP VHS tapes to capture and just a standard JVC VCR (SVHS decks are impossible to come by here in Aus). I'm tossing up between this and a dedicated TBC (eg CTB-100) to help reduce the number of dropped frames I'm getting. Note that none of my tapes have any copy protection, so this isn't a consideration - I'm looking at a TBC to improve the capture quality only.
Thanks,
Mick
Results 1 to 1 of 1
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 20:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 10:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 02:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 12:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 09:29
