I was just at newegg.com and I couldn't find any 5.25 enclosures for firewire.
Would a USB 2.0 5.25 enclosure be adequate for a Bluray drive?
The reason I'm asking is I do have two SATA connections on my motherboard. However my boot harddrive takes up one slot and the 500gb harddrive I just bought is a sata and takes up the second connection.
I do have a free pci slot where I could get a sata power card. Would that be a bad thing if you already have a sata port on your pc? I do have a spare sata power plug so that is not an issue. I just don't have a sata connection available on the motherboard.
So would I be better off getting a sata card so I can do the bluray drive internally? Or would it be ok to use a usb 2.0 5.25 enclosure for the drive?
If there is an adapter to add on to the existing hardwired plugs on the motherboard I'd be interested in a link. Thanks.
Here is a link to some firewire enclosures...
http://www.cooldrives.com/525usbfircas.html
from New Egg...
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=firewire+enclosure -
Finding a 5.25" firewire or USB 2.0 enclosure - the trick is finding one who's internal interface is SATA - most are IDE only. Addonics has one that is both.
http://www.amazon.com/Addonics-AE5SACSU2-External-Drive-Enclosure/dp/B0002XHBXE/ref=pd...8115749&sr=8-3 -
I have two PCI SATA controllers with external connectors for eSATA or SATA on one of my computers, along with the on-board SATA, and they all get along fine with each other. A external SATA enclosure will have it's own power supply, so you don't need that from the computer. Of course your Blu-Ray drive would have to have a SATA interface.
Here's a few external SATA enclosures: http://www.cwol.com/serial-ata/sata-drive-enclosures.htm -
Thanks everyone I'll keep these in mind. And thanks redwudz I'm glad to hear a pci card will work happily with onboard ports.
EDIT - I bought a pny two port/internal and external sata pci card today. You can do two internal or two external. I didn't check when I installed but I hope its set to internal by default. Anywho know I'm set. As soon as I buy my bluray drive next week I'll be able to simply plug and play
Thanks everyone
Take out drive from BluRay player?
By satviewer2000 in forum DVD & Blu-ray WritersReplies: 6Last Post: 5th Oct 2011, 16:29 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 15:05 -
Is using a Bluray drive better than a regular DVD drive?
By imfallen_angel in forum DVD RippingReplies: 14Last Post: 20th Mar 2010, 21:49 -
Enclosures with FireWire IDE or SATA?
By Sakuya in forum ComputerReplies: 15Last Post: 20th Jan 2009, 19:44 -
USB or Firewire for HD capture; HD movie to DVD or only to BluRay
By AVSrell1k22 in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2009, 17:29
