I had my1960's 8mm professionally transfered to dvd. They did nothing about fixing the lame colors.
I would like to be able to know if there is a freeware that will take this mp4 and do a one button press color restoration. Something similar to what adobe photoshop does to old photographs.
Can it be done?
big learning curve or simple?
freeware or must $$$$ ?
Results 1 to 16 of 16
Depends on the video. You should post a 5MB segment of it up here and we'll take a look. It might be easy, or it might be impossible. It completely depends on the video.
Thank you for the reply.
How do I make a video available on this site. Dont I need editing software to cut out a 5mb section as you requested? -
Depending on the format, you should be able to cut a section out with VirtualDub. VD or VDM can also use quite a few filters for color corrections with AVI type formats. I would also recommend the Color Mill filter in VDub or VDM for adjustments : colormill2.1.1.zip But you will have to re-encode to make these adjustments.
And andersonmilltexas, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
The conversion house gave you the video on DVD, right? How is it MP4 ?
The DVD is a video TS folder with vobs.
No copyright or any type of proetction.
I can not even do a copy for copy.
I tryed Nero 7 ultimate, shrink fab and the best I get is a dvd with no sound.
Step by step.
1. Put ogiginal copy into dvd player. Hit copy and pasted contents into new folder.
2.opened Nero did a burn
results = no sound.
Step by step with decrypter
1. Decrypted ( never had protection)
2. ended up with a TS Video folder
3. Went to shrink (nothing needed compessing)
4. Burned using shrink
No sound
I am goofing up something but what
thank you for your help -
Just copy the vob files off the DVD as though they were regular files. No need to do any decrypting. If you put the disk into a DVD player, does it have sound?
You might drop one of the VOBs from the decrypted VIDEO_TS folder into Gspot 2.70. Check that one against one from the original DVD, especially in the audio section. You can also post a screenshot here from Gspot from both or either:
https://forum.videohelp.com/topic271697.html -
Yes, The DVD has sound. I load the disk copy and paste files into folder then I am able to take any program ie shrink, load the files do a preview and it has sound.
I could try g spot !
What bothers me most is that I shouldnt have to constantly be downloading freeware programs everytime I want to burn a regular old unprotected dvd. I have nero, and nero is a pretty good program. I just want simple plug press one button and play. I do not burn enough dvds to make it worth alearning new products. This is frustrating. -
This is the VOB take straight from the DVD.
General #0
Complete name : C:\Documents and Settings\HP_Owner\Desktop\DVD Destination folder\transfer by copy and paste of wedding video\VIDEO_TS\VTS_01_2.VOB
Format : MPEG-2 Program
Format/Family : MPEG-2
File size : 756 MiB
PlayTime : 37s 380ms
Bit rate : 170 Mbps
Video #0
Codec : MPEG-2 Video
Codec profile : Main@Main
Codec settings/Matrix : Custom
Bit rate : 9334 Kbps
Bit rate mode : CBR
Width : 720 pixels
Height : 480 pixels
Aspect ratio : 4/3
Frame rate : 29.970 fps
Standard : NTSC
Chroma : 4:2:0
Interlacement : Top Field First
Bits/(Pixel*Frame) : 0.901
Audio #0
Codec : AC3
PlayTime : 25s 338ms
Bit rate : 384 Kbps
Bit rate mode : CBR
Channel(s) : 2 channels
Sampling rate : 48 KHz
Video0 delay : 12s 714ms
ChannelPositions : L R -
This is the VOB after running through DVD decrypter.
General #0
Complete name : C:\Documents and Settings\HP_Owner\Desktop\DVD Destination folder\wedding trying on dvd decrypter\VTS_01_1.VOB
File size : 1023 MiB
PlayTime : 12s 452ms
Bit rate : 689 Mbps
Video #0
PlayTime : 12s 353ms
Bit rate mode : CBR
Width : 720 pixels
Height : 480 pixels
Aspect ratio : 4/3
Standard : NTSC
Chroma : 4:2:0
Audio #0
Codec : AC3
Bit rate : 384 Kbps
Bit rate mode : CBR
Video0 delay : -67ms
Now I cannot hear audio on any mpeg 2 that I have ever made. The same dvd will give sound on a standalone player but not on my computer.
Only recent changes I have made is a Nero update. Both events seem close in time.
It is only affecting mpegs that I created not Mpegs created elsewhere.
Does anyone have any idea?
THX -
New Development.
Everything Has sound If I play it through Nero only.
Nero blocked me from listening from anyother Player.
How come and how do I fix that? -
Nero has apparently tried to take over your video playback.
The specs of the original video and the copy look fine. I would try VLC for playback instead. It's uses it's own codecs and ignores installed codecs. If it works properly, then you likely have a codec problem or a association problem, at least for playback.
Just looking at all that, Nero is not your friend.
Maybe OK for encoding, but it looks like it messed up your playback. AC3 audio should be fine on any settop player. For most computer software players, you need a AC3 codec installed.
I'm not sure if you can easily remove the Nero player, but you can change the associations of your videos to different software players. -
Thank you
I did a reinstall and things came back. I do not like it when software tries to push out the competition that way.It is sneaky.
I appreciate your help.
MSU Old Color Restoration alternative?
By magillagorilla in forum RestorationReplies: 55Last Post: 30th Jul 2011, 13:30 -
MP4 editing > Freeware software that will do it!
By Bodh1 in forum Newbie / General discussionsReplies: 10Last Post: 30th Jun 2010, 02:59 -
8mm film and the msu old color restoration filter
By buckethead in forum RestorationReplies: 14Last Post: 23rd Jul 2009, 00:06 -
Color Adjustment & Restoration
By headless chicken in forum MacReplies: 11Last Post: 26th Dec 2008, 03:42 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 02:44
