hi, im using the latest divx codec and divx convertor.
at the momment the divx convertor only goes up to the high def profile and not the HD profiles which are included in the latest codec.
Is there anyway to update divx convertor so i can use them? or do i have to do it manually though virtualdub, because i dont like the looks of all the config options, had a look at the divx guide but im still unsure what settings to use in vdub.
got a hd source 1920x1080
The latest version (v6.1) supports the latest codec. You need to update the converter.
Google is your Friend -
If you have the commercial Divx codec, Dr. Divx is really superior to Divx Converter. I recommend Divx Converter only to people who are unwilling to use anything but a 1 click solution and are willing to live with the fact that the Divx Converter gives you no control at all over the output. If you want to record HD Divx files, do yourself a favor and ditch Divx Converter in favor of Dr. Divx.
thanks 4 the help, will give both a try see what results i get, thanks.
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 12:20 -
Xilisoft DVD to Divx Convertor
By didikai in forum Newbie / General discussionsReplies: 3Last Post: 7th Feb 2008, 14:23 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 17:25 -
Cropping in Divx Convertor or Divx Author???
By rahul.never2far in forum EditingReplies: 9Last Post: 25th Sep 2007, 10:28 -
DIVX convertor / resolution
By surfer in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 03:56
