I have a lot of VCR casette and wishes to convert to VCD, SVCD or DVD.....
But i have no idea![]()
Anyone out there knows about that, please help me......![]()
Can indicate what software to use.....
Can suggest any capture card to use as budget for getting one is low...
System
PIII 550Mhz MMX
IDE 10 Gig 5400RPM HD(maybe ATA66)
576Mb SDRAM
Video Display TNT M64 32M SDRAM
Ricoh CD Writer +Nero 5
OS Win98
Creative Vibra128 SoundCard
how about having as look to the left between WHAT IS and OTHER theres a section called HOW TO give it a read all you need to know is there it is fairly detailed even what tools youll need
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
How to cut and join DAT Video file with womble MPEG-VCR without conversion?
By kitharass in forum EditingReplies: 0Last Post: 11th Mar 2010, 12:57 -
Issue: Background noise on DVD following conversion from VCR tape.
By Beech Cricker in forum Newbie / General discussionsReplies: 16Last Post: 6th Feb 2008, 10:37 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 02:02
System
