I bought a Hitachi DZ-GX5080 last weekend, and I bought a 5 pack of 80mm
DVD-RW discs. I recorded a bunch of just random stuff at different
quality settings then I finalized the DVD using the Camera, but when I put
the DVD in my XP or Vista machines it doesn't play them but i can explore the discs.
The directory structure is like this from my PC's:
DVD root
-DVD_RTAV (folder)
--VR_mangr.bup
--VR_mangr.ifo
--VR_Movie.vro
-RTR_EXTN (folder)
--rx.dat
--VR_Stdum.000
.sys-reserved-rw-bitmap.grow
If i place the disc back in the camera i can play back these files but no
longer have an option to finalize the disc. I have the option to format the
DVD again but I don't want too do that. I'm going to put it in my DVD player
tonight (Xbox 360) and see if it will play back but I doubt it. I did find
this though:
http://www.mediostream.com/Products/index_DVDVRextractor.html
But I don't want to have to buy something to just view my DVD home movies on
my PC, that was the point of straight to DVD. Is there a better way to do this for instance formatting the MiniDVD's differently using maybe VF mode instead of VR or a different media type? I want to get this as simple as possiable before my first born daughter arrives in Feb so i can share the discs with friends/family.
Thanks!
Results 1 to 11 of 11
Will The --VR_Movie.vro Play if you open it in a player?
My experience with dvd-cams is limited, Can you see the vts and vob files thru your comp (Im assuming Windows) If you can copy them to your desktop or a file you can find. Then Take a free program like IMGBURN and build and ISO (there are tutorials and walkthroughs for doing this easily) Then IMGBURN will burn it to a dvd for you to use.
Another test would be: Explore the dvd drive with the dvd-rw in, You should see "VTS_01_1" And more but start here. You can play the individual Vts files.
I had to finalize the disks before they would play in a computer or dvd player. But I didnt like the menu so I used other programs to change all that. Like I said I only have limited experience with DVD-Cams but enough to stay away. Good Luck
Best Regards
Jensen -
Even after i finailzed the Disc i still have the same dvd structure as before, i'm assuming that VR_Movie.VRO is the actual movie since it is rather large but i've not found any way to play that back on a PC. And compared to a normal DVD Movie disc this structure seems strange to me.
I did just find this, but it cannot possiably be this easy can it?
http://www.cdrinfo.com/Forum/tm.asp?m=107425&mpage=1𛞉 -
From What I can see vro is a codec, find the right codec from Hitachi. Or you can search thru a ton of codec-packs. Do you have a software disc from Hitachi that might have the right codec on it? Ill keep searching for one.
HV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
Hey try it!! Cant hurt you'll have original copies on your disk anywhase!
I found this on this forum
https://forum.videohelp.com/topic333178.htmlHV30+Wide Angle HD Lens, Rode Stereo Mic, Manfrotto Tripod System, Canon ZR 850 -
I was able to copy to .VRO file to the PC and rename it to .MPG but i lose any "Chaptering" thats done by the camera it becomes one big movie. Is there an application that will retain the chaptering done on the camera?
it appears that AVS Tools and DVD Interigator will covert .VRO to DVD but i don't know if it will retain chaptering i'll try tonight and see.
http://www.avsmedia.com/VideoTools/index.aspx
http://www.authoringware.com/vro_main.htm -
The VRO file is your movie. This is similar to what you would find from a DVD recorder.
Have you tried using DVD-Shrink or similar program?
There are a few programs that will edit the VRO/VOB files directly "MPEG Video Wizard" is one and "Ulead DVD MovieFactory" is another (I am sure there are others). If you just want to convert the data to a standard DVD try DVD-Shrink and if you change the file from VRO to VOB or MPG then the files referencing the VRO (your chapter info) will not work. ONLY change the file name if you intend to edit and not use the existing chapters. DVD-Shrink if it works will re-create a new copy but a standard DVD VOB version with chapters menus.
You can download a trail version of Ulead DVD MovieFactory. I would try this program first. To me it is simple to use and makes it easy to add chapters, edit and build a dvd interface quickly. You would be able to put about 4 of the mini-dvds onto one standard DVD, if you are using DL-mini DVD's then you can only put about two of them on to one DVD disk.
Good Luck -
I seem to have found the solution to my issue, aside from my first MiniDVD i recorded in VR mode, i still have to convert that. But going forward if i record the MiniDVD's using the VF mode it creates a DVD that uses "Standard" directory structure and formatting that is readable on stand alone DVD players. VF mode doesn't have all the abilities of VR but it creates the most compatible disc.
So if anyone buys a DVD cam and is having trouble with compatibility my advise is to use VF mode if it's available.
Thanks for everyone's suggestions, Merry Christmas!
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 06:15 -
region code assistance with the sony dvp-ns700h DVD PLAYER
By stressed_with_sony in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jun 2009, 01:06 -
Toshiba DVD RDXS34 Users, your assistance please
By DJL82 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Feb 2008, 22:13
