I got a used Toshiba DR-2 from a friend a few months ago and bought some DVD-RAM disks to allow me to pause TV. So far everything has been going great with it except for some really odd reason once I remove a disk that I have been using and to put it back the recorder says the disk is damaged. If I eject and insert the disk 100 times eventually it will recognize the disk and everything will work fine.
Is there anything I can do to improve the drive (like modify a POT) or anything like that. I really like the recorder but right now its almost useless since it won't use my disks.
	Does the unit have a Format DVD-RAM option anywhere in the menu? Try that on one of those disks if it does.
  Computer wonīt recognize DVD diskBy dexter30 in forum MediaReplies: 10Last Post: 4th Sep 2010, 15:52
  PC won't recognize burned files to DVDBy browndav in forum MediaReplies: 6Last Post: 9th Jan 2010, 16:43
  Toshiba DVD Drive does not recognize Philips DVD-R mediaBy garybeck in forum DVD & Blu-ray WritersReplies: 12Last Post: 5th Nov 2007, 13:57
  Sonic won't recognize DVD, computer does ...By LittleQueenie in forum Newbie / General discussionsReplies: 2Last Post: 17th Oct 2007, 14:06
  Toshiba Satellite Vista laptop won't recognize ram upgradeBy edong in forum ComputerReplies: 17Last Post: 25th Jul 2007, 22:49
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
