I’m adding permanent (non Latin fonts) subtitles to some DivX /XviD movies, for playing on a stand alone DVD player with DivX /XviD support - normally I could use Avisub22 (an excellent program, doesn’t reconvert the video – I think), but doesn’t work with all the .avi files. Some times the program can finish without any errors, but the avisub file I got has no video – only sound, other files are just fine and perfectly playable with permanent subs on the DVD player. Because of this problem, some times I prefer to use the other excellent program Txt2Vobsub, it converts only the subtitles from ***.srt to ***.idx and ***.sub and the DVD player shows them correctly.
The only problem I have with it is the color palette when played on DVD player. Generated idx/sub subtitles look just fine on computer, but look very weird, blurry, and pinkish-bluish - and, basically, unacceptable on any DVD player with which I tried them. I read the tutorial, and see that there is a suggestion to use color scheme from IFO file. I tried that too without success.
The fact is - there is a movie in .avi format, and subtitles in .srt. That's it. If the srt was in ANSI, it would be no problem either, because a DVD player can support srt subtitles with Latin fonts.
But my subtitles are in the language that uses different charset, so I have to convert srt into idx/sub.
So - back to my question. Is it possible to set color palette in idx/sub?
Does anyone manage to use it properly?
......I experimented a little bit with the Colors options, when I set Antialias, Outine and Text to white – I’m getting all black subtitles – not readable and not nice looking, but this means that maybe there is a combination of colors that can set the color palette to White.
I tried with all black and I got the same black subs. If I put the “Antialias” to Grey, “Outine” to black and “Text” to white, the result is funny looking pink subs with dark blue shadows. Some other combination gave me black subs with blue shadows……
So three columns with 15 colors each = 3375 combinations, it will take forever to guess…. -
So, my friend? Could you guess the combination at last? Im facing the same predicment right now...
All u need is a software VobSubStrip comes with K-lite Codecs. Make an sub/idx file with PC only color option. After creating it, put it in VobSubStrip and process it. It's Done. LOL -
All u need is a software VobSubStrip comes with K-lite Codecs. Make an sub/idx file with PC only color option. After creating it, put it in VobSubStrip and process it. It's Done. LOL[/QUOTE]
Thanks, but at last there was no need of any external program. Txt2Vobs has the "PC only" option, only I hadn´t found it yet. It works as a charm on my Oppo BD. -
thanks for this program,,,
vesion 4.2
Problem with color,, I use some color,, it work fine and does not change when i generate separate subtitle ,, but when I use batch files for multiple sub, all color is change and nothing as i want,, let say I make font color yellow,, when i use it for batch it change all to white...
anyone has an idea
Color streaks appears once converted to Xvid
By 24fps in forum Video ConversionReplies: 5Last Post: 17th Jan 2011, 04:45 -
Change from a color to another in a video
By Nokiamania in forum EditingReplies: 4Last Post: 7th Jul 2008, 02:51 -
ConvertXtoDVD - Can't change subtitles color
By Phil240 in forum Authoring (DVD)Replies: 5Last Post: 8th Dec 2007, 04:03 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 23:26 -
Subtitles : lower position / change color?
By izzat in forum SubtitleReplies: 2Last Post: 25th Aug 2007, 11:21
