Here is my problem:
I have videos that I make myself that i'd like to add a logo or text (like you see on television stations).
All my videos are in .avi format, and I'd like to keep them that way.
I've tried Adobe After Effects, Final Cut, doing it through Quicktime, but they all don't give me an option to input the .avi, overlay my logo, and quickly export or render them to an .avi again.
Does anyone know a simple way of doing this?
I know there are tons of programs for Windows which allow you to do this, but are there none for Mac?
Thank you.
All editors allow for overlays or they wouldn't be editors now, would they?
Look again with whatever you're using -
They all allow for overlays, but once I overlay on an .avi, most will only export to a .mov format, not allowing me to simply render or export quickly back to an .avi.
that's because you have changed the file.
The file is now something new, and you will need to export to
the proper file type.
If I was doing this say, in quicktime, I would export out as a reference
.mov file, there by referencing my original avi and my logo graphic,
and then I would drag and drop this into VisualHub to make a divx .avi.
In FCP, similar thing, but instead of a reference .mov, I would just export to
a Quicktime .mov file, then drag/drop into VisualHub.
This is normal behavior for the apps you mentioned..."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Thanks terryj, that's what I thought.
I just am trying not to have to go through the work of encoding my work, overlaying the logo, then encoding it again. -
Unfortunately, with any type of editor, that is what you'll get.
U r welcome. Happy Holidays!"Everyone has to learn, so that they can one day teach."
Urban Mac User
overlay my logo question
By bearmon2010 in forum EditingReplies: 6Last Post: 13th Dec 2011, 08:44 -
How to hide the Random Logo coming up in in AVI file
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 1st Feb 2010, 01:56 -
Adding Overlay Or Logo
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2008, 14:38 -
Adding animated logo to an avi file
By andy_blah in forum EditingReplies: 17Last Post: 27th Aug 2008, 22:03 -
virtual dub logo avi too big
By forchristians in forum EditingReplies: 5Last Post: 20th Sep 2007, 23:47
