I have Topfield digibox and when I demultiplex files, I get .m2v, .mpa and .sup streams.
Now I need to find a software that can easily multiplex all these files and author DVD. Is there any freeware available that can easily do the trick? I should also be able to include more than one movies into one DVD so that might also decrease my possibilities ...
Thanks for your answer in advance.
Edit: it was .sup stream and not .sub
I admit that it is a long shot, but why not take a look in the tools section under Authoring (DVD)?
I use GUI for dvdauthor myself.In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
You can try GUI for DVDauthor. I've never been able to get it to work for me because of DLL hell on my PC, but I have a lot of crap installed that you probably won't have, so most likely it will work OK for you.
I'm not sure if anything support SUP format subtitles, so you may have to convert those to another format. I'm not sure. -
GUI for DVDauthor supports sup subtitles. It is the standard if you use it with MuxMan as authoring engine (recommended for sup subtitles).
@jman98
Does it directly crash on your PC when you start it, or what's the problem?
Have you tried the MuxMan mode already?GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks for your answers. I have to try this even if it doesn't seem to be the most easiest one...
I hope that those guides really help
Now I'm a little bit confused
There are many guides for this software but what is the easiest and best one that instructs how to create basic DVD menu with few movies inside (including subtitles seems to be quite easy). For example I didn't understand what this "Create batch" means (there was these instructions https://www.videohelp.com/forum/viewtopic.php?t=255213).
This batch is something I haven't faced earlier with softwares I've been using for DVD authoring (for example early version of DVD-lab).
Thanks again. -
There is a learning curve but once you're started it is very easy. I recommend the help files. Open GfD, go to help - index, and choose "Multi VTS Example" (fifth from the top), I think that is exactly what you need.
subtitles with TMPGEnc Dvd Author 3
By yoshiboy37 in forum Authoring (DVD)Replies: 3Last Post: 26th Dec 2014, 04:31 -
How to author a god damn dvd with subtitles?!
By Redhotpengy in forum MacReplies: 7Last Post: 7th Jan 2012, 04:51 -
AppleScript Error when trying to author DVD with subtitles
By Chopper Face in forum ffmpegX general discussionReplies: 5Last Post: 2nd Jul 2008, 23:25 -
Question how to add subtitles with TMPGEnc DVD Author 3
By jimdagys in forum SubtitleReplies: 1Last Post: 5th May 2008, 17:24 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 00:21
