ImgBurn is burning only half of my DVDs!
I have been converting .avi files into iso's using FAVC, and burning them onto DVD-R's, four episodes per disc (bitrate 3043, half-D-1). It takes FAVC like 8 hours to finish making the iso--so I have been delegating the task to multiple computers, since I only have one DVD burner.
here is the really frustrating part!!!!
imgburn works fine when i let FAVC open it automatically and just click "go" (well, actually a few discs have failed in the burn process, but for different reasons.)
but ALL of the discs that I burned after transfering them to the computer and opening manually with ImgBurn kill the last few episodes! The first and maybe second episode work, but the last ones dont! and the disc is obviously less than halfway done burning, you can see the area where it stopped. ImgBurn thinks everything was fine though!
Here is what I have been doing (i've been trying different things, so it might not be exact):
1. FAVC creates "dvd 0.iso" (319,200KB) and a folder called "dvd 0" which contains "AUDIO_TS" and "VIDEO_TS".
2. I open ImgBurn in write mode.
3. I "browse for a file" and select "dvd 0.iso"
4. (at this point it says "time: 35:30:00"???)
5. I click the "burn" icon and it goes through the process "successfully"
what am i doing wrong? this is very frusterating as I have lost days and days worth of processing time making these isos, and many discs, and only have one DVD that actually works to show for it!
Results 1 to 9 of 9
Sure it's 319.200 KB? That's 311 MB, not even 1/10th of a DVD...FAVC creates "dvd 0.iso" (319,200KB)
/Mats -
aaah, i knew that couldn't be right!
I thought maybe it decompressed or combined the iso with the stuff in the folder. why is FACV making such small isos! -
I've had some run-ins with FAVC stopping short when converting too. Never dug deeper, as I really have no reason to do AVI to DVD other than as an etude.
/Mats -
That's what happened to me.Originally Posted by redwudz
/Mats -
There is a general problem with FAVC which relates to Muxman/Batchmux.
It seems very sensitive to (what I guess are) bitrate spikes. It causes Muxman to quit with an error (check the muxman log in the working folder) saying that the dvd has been muxed but it probably won't play smoothly. In fact Muxman doesn't finish muxing the dvd and the dvd structure is not created properly.
The problem seems intermittent. For some source files it works okay and for others it will fail. Unfortunately, the only workaround is to lower the maximum bitrate until Muxman accepts the file.
I've tried contacting the author of Muxman and had no reply. The other free dvd author package out there that I know about is dvdauthor, and that is not without its problems too. -
This is the type of error from the Muxman log
The created dvd structure has no bups and a 0 kb ifo.Video decoder buffer underflowed 5 times.
Check c:\muxman.log for details.
Resulting DVD will probably not play smoothly.
Creating MDS file automatically When ripping to ISO With ImgBurn
By bbanderic in forum Blu-ray RippingReplies: 2Last Post: 2nd Feb 2010, 22:53 -
Why Imgburn makes me happy
By Des in forum Newbie / General discussionsReplies: 21Last Post: 11th Sep 2009, 15:18 -
How do I burn using Imgburn?
By rocky12 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jun 2009, 16:05 -
Help making ISO with ImgBurn
By stantheman1976 in forum Newbie / General discussionsReplies: 6Last Post: 17th Jan 2009, 18:04 -
HELP! FAVC 1.04- Why is it creating 0 byte iso's at times?
By spexwood in forum Video ConversionReplies: 7Last Post: 6th Dec 2007, 00:40
If both the VIDEO_TS folder and the .iso file are undersized, then
