Hi there,
The scenario is: I have all the codecs installed (K-lite), fresh new Win XP install, 3GHz CPU enough RAM
I also tried encoding in DIVX (thru VirtualDub) with no success, it seems that VirtuDub is making the problem. Also the video looks crappy, thank god I'm using Lathe encoder right now (a $5 program, suprisingly good, but only limited to 640x480) where I can cut out unwanted video and use batch processing.
But I can't do anything with VirtualDub, encoding is faster in VirtualDub? Lathe only uses 50% of the CPU.
Can somebody tell me what could be happening?
What am I doing wrong?
Everybody seems to be using VDub w/ any problems.
What are your thoughts?
Kbal
Tried AutoGK or avi.net? Unless you're really a guru at configuring the XviD codec, these apps do a better job than most mortals.
/Mats -
kbal,
Why don't you cut/edit commercials before you do your encoding?Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
VirtualDub. Just set audio and video to direct stream copy before your save out.Originally Posted by kbal
/Mats -
Yeah I can do that, but it will envolve more steps to make, that's why I like Lathe (to a point), its all in one pacakge, I'm not worried about saving new (edited) file with different name, then opening another program and encode it there, blah blah. Lathe has few steps, but not all the features, and possibly not the best quality video output. But yeah I'm trying to do that right now with VDub and then maybe encode with AutoGK or avi.net
I'll have to see what gives me the best quality output. Or later maybe just get the Archos 605 wifi (best video player there is) and not worry about any of that stuff.
Kbal
www.archos.com
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 11:35 -
Enconding Megui Xvid error :/
By psygno in forum DVD RippingReplies: 0Last Post: 2nd Sep 2011, 06:27 -
ac3 audio and xvid video in avi out of sync
By socrates in forum Video ConversionReplies: 10Last Post: 15th Jul 2011, 21:58 -
Audio - Video Sync Problem - VirtualDub
By cyberlion in forum EditingReplies: 13Last Post: 16th Jul 2010, 07:51 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 09:33
