  1. Would someone be so kind as to let me know what third party codecs that I need to download and install before using AutoGK? Thanks so much in advance.
  2. XVID and DIVX or either one on its own.
    DIVX.COM
    The electronic components of the power part adopted a lot of Rubycons.
  3. XviD's included with the AutoGK download; DivX isn't. Make sure you get the latest ver 2.48. Don't use 2.45. If you plan on making AVIs using the XviD codec, everything you'll need is included. Don't install any codec packs. If you already have an XviD codec installed on your computer, be sure and uninstall it first (Add/Remove Programs) before installing AutoGK and the included XviD. Use the XviD included with AutoGK.
  4. Thanks ever so.
