  1. When i try to merge&cut a mpeg file, i got the next message:
    AT address 73F01D04. Read error occurred against adress 73F01D04.
    What does that means?, How can i solve the problem, and what most stay in output?
    Krammie
  2. i get the same problem, you are running TMPGenc under XP are you??!!
    just ignor it, type in the file name and press the button run...
    it should work just fine!!!
    as long as my boss thinks i make a lot of money, i will pretend to work hard ;)
