I'm looking into buying a HD DVD Recorder with built in Tivo. Mainly to record tv shows and sports (live boxing).
Im just curious if a fight or movie is 3 hrs long how would you able to fit it onto a DVD?
I know that XP or fine mode is highest qualty and can only fit ONE hour onto a single DVD.
So does the HD DVD recorder allow you to keep inserting blank DVD's until you get all 3 hours of boxing in 3 separate DVDs? I want all 3 hours while preserving the best quality.
Or if it runs more than an hour am I screwed and cant burn it onto a DVD (in highest qualty) cause it's longer than an hour?
Please let me know, never owned a DVD Recorder so not sure how the format works. I still use VHS to record stuff on tv.
I assume by HD, you mean Hard Drive. The convention these days is to call a hard drive DVR a 'HDD' DVR. The HD title is more often used for 'High Definition'. Or if you mean 'High Definition', you might want to state that.
If you have a HDD DVR, then once you get the video on your hard drive, you should have some options for burning. If the DVR lowers the bitrate for encoding, you can get quite a bit of video on one DVD. Of course, the longer it is, the lower the quality will be. Three hours shouldn't be a major problem, just not the same quality as a one hour video burn.
And welcome to our forums.
IF you have a recorder with a HDD, you can record up to that machine's max. continuous rec. time... Philips DVDR3575 is 12 hours in one recording... at any rec. mode, including 1-hr-HQ (the best mode).
IF you're just going to watch your recordings, you're home free... nothing more to do but watch.
IF, however, you now want a long HQ recording on one or more DVDs, then you'll have to split it into hourly segments (using Edit/Divide) and put each hour on one DVD. You'll be able to use High-speed dub for each hour, which will preserve the HQ quality bit-for-bit.
IF, however, you can stand the extra time and quality donwgrade, you could dub a DVD at a lower-quality rec mode in real-time... i.e., switch the dub rec mode from HQ to SP for two hourly segments, all the way down to 6 hourly segments at 6-hr-SLP mode. -
btw I just bought a brand new PIONEER DVR-810HS for $230. Good deal? This is my first HDD DVD Recorder.
$230? That's odd, considering that:
dvr810
Regular price: $1,199.00 You pay: $693.99
http://hometheaterphiles.stores.yahoo.net/pidv1.html
Nice deal.
Reviews:
http://www.amazon.com/Pioneer-DVR-810HS-Recorder-Basic-Service/dp/B0000YDALM
Requires TIVO
Question about DVD Recorders - Can I plug a VCR to it?
By donovan99 in forum Newbie / General discussionsReplies: 9Last Post: 23rd Aug 2008, 11:28 -
Newbie question about archiving on DVD recorders
By Soupcan in forum DVD & Blu-ray RecordersReplies: 11Last Post: 4th Aug 2008, 22:58 -
Ok, here's another dumb question --- tuners in DVD recorders?
By Trollheart in forum DVD & Blu-ray RecordersReplies: 7Last Post: 7th Mar 2008, 11:28 -
Question on new Panasonic dvd recorders
By heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 11:37 -
Basic DVD Burning Question
By harryk in forum Newbie / General discussionsReplies: 1Last Post: 5th Dec 2007, 04:55
