someone please help! I have looks around for days but can not find any help...
I am running Vista Home Premium on my computer with a 4:3 Samsung LCD. While surfing the internet, I turn on WMC with a Happague 250 TV card and watch TV in 4:3 format in the corner of my screen. About a week ago, WMC opened in a window that was 16:9, thus leaving my basic cable signal displayed in 4:3 mode with pull down black bars on either side. Any attempts to re-size the window, keeps the 16:9 ratio. This window takes up too much room on my screen and I want WMC to open in 4:3 mode. I have been to the settings screen and run the wizards to no avail. WHere is this setting?!? It is driving me nuts!
				Results 1 to 10 of 10
	never seen that, however have you tried going to www.microsoft.com and searching there? Or www.google.com and searching. You'll have better luck that way.
 Just from curiousity you didn't set the MCE TV settings to 16:9 did you?
	Been on both sites and couldn't find a solution.
 I didn't change any settings, and I have run the wizards several times, making sure I have it set for 4:3.
 When I play the window full screen, it shows 4:3. Its only when its a smaller window that it takes on the 16:9. Any attempts to re-size maintain the 16:9.
 This may soon be a moot point as I plan on getting a 16:9 monitor, but I just can not believe this setting is buried somewhere and I can't find it!
	After about a month of pulling my hair out... I have found a solution...
 Try re-sizing you Windows Media Center while holding your CTRL key. You can switch from wide screen to 4:3.
 Enjoy this little (useless) nugget of information and realize I have lost sleep over this one!!!
	I haven't read/posted in this forums for ages, but videohelp was my first google hit. I must say, that holding the control key while resizing MC does change the aspect ratio. I have a 16:9 monitor but also VGA going to my 4:3 TV. This must be by far, one of the stupidest places to make that change. Why not just simply put it in Settings -> General -> MC Setup -> Configure your TV.
 Thanks!
	Thank you! Was driving me crazy with my windows 7 set up, first hit on google (as mentioned above) pointed here. Ctrl + window resize drag worked.
	I had the same problem, the Windows Media Centre window switched to 4:3 where it had always been 16:9 before.
 Thank you for this tip, the Ctrl key and drag to resize, works and I'm now back to 16:9.
 This seems like the most obscure way MS could have implemented this setting (what's wrong with a menu option?), even if once you know how it seems obvious.
	I recently had the same problem with media center, just opposite yours. Mine went to 4:3 and I wanted 16:9. Had no idea why. Control/resize is such an easy solution, but I had no idea. Thank you for posting, it became a quick easy fix for me because of your post.
  RCA to hp media centerBy outlawz89 in forum Newbie / General discussionsReplies: 4Last Post: 30th Jul 2011, 13:54
  Media CenterBy superc in forum LinuxReplies: 4Last Post: 7th Jan 2011, 20:39
  Best audio settings for MP4 on Win Media Center & Mobile Players?By thefiddler in forum Video ConversionReplies: 8Last Post: 14th Aug 2010, 07:58
  Sharing TV - 1 Vista Media Center Server to Vista Media Center PCBy JBredensteiner in forum Media Center PC / MediaCentersReplies: 8Last Post: 14th Jul 2007, 02:33
  Media Center HelpBy rwheeler in forum Video ConversionReplies: 4Last Post: 25th Jun 2007, 14:06
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
  Visit Homepage
				Visit Homepage
