Having read the posts concerning Pal/NTSC capture. I need some basic info about WinDV. I capture from my Cannon minidv and when I used WinDV, it gave me several .avi files. Most capture programs just give me one large file(6-10gb), that I store on my backup HD, burn to DVD, then erase. (Mainly family stuff and grandkid Bball games). How do I get one large file from WinDV? Enosoftdv started giving me problems and I can do it with Vdub, I don't understand all its options.....
	In the Config menu change Discontinuity Threshold to 0 and set the Maximum file size to 150000 and you'll transfer an hour as one file
	There is also this guide which explains all the WinDV settings: http://www.dvd-guides.com/content/view/33/59/
  Should I use WinDV?By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 18:23
  Windv to harddriveBy runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 05:36
  Cannot use windv with usbBy Riff88 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Apr 2009, 16:04
  WinDVBy kippard in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2008, 00:43
  Windv SchedulerBy ScottEslick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2008, 22:46
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
