There are two titles.
Title 1 is 1 hr 26 min
Title 2 is 1 hr 41 min
WHich is the correct title? I just want to backup the main movie?
Check the special features list to see if there is an "extended version" of the movie in addition to the "theatrical version". If so, title 2 is probably extended while title 1 would be theatrical.
Usually, the DVD will 'navigate in' the extra scenes but a lot of rippers/transcoders cannot "see it" that way, so they list 2 separate titles. It is also possible that there are actually 2 separate titles... one for each version.
Again... check the special features list for 2 versions of the movie and pick the one you want.Even a broken clock is right twice a day. -
I believe the longer version has extras added if you select the commentary audio track.
They must branch off at certain times...nothing to do with the main movie.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
A "why did they do that?" and question about "retro-editing" (if you will)
By takearushfan in forum EditingReplies: 10Last Post: 31st Jan 2010, 22:02 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 14:46 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55 -
getting "fuzziness" in the simpsons, family guy...
By Sunshine1223 in forum Newbie / General discussionsReplies: 7Last Post: 22nd May 2007, 18:20
