Hello. I cannot get any VCDs to work in the Xbox, regardless of the media (xbox.aimx.net).
I was wondering if there is a way to convert these .pgs and .dat files, or any type of file I could add on the cd and the player will be fooled into thinking it is a dvd.
I am unsure how dvds work, is it just a boot sector? Or is the entire file encoded differently?
Thanks.
I don't own an XBox but from what I've read it does not support VCD or SVCD at all, even with the DVD kit. I do not think it has player software support for the VCD/SVCD formats. If true, it is surprising because the XBox DVD player software was licensed from Ravisent Cinemaster, which does support VCD in their PC DVD player software as far as I know.
However I read a few unverified reports that XBox does support MiniDVD or "cDVD", which is just a DVD image burned to CD-R/RW media. You might try authoring a MiniDVD at 352x480 and 2500 bitrate. Let us know if it works.
The XBox is very picky about the CD media from what I've read, and very few CD-R media are supported. You should try CD-RW media instead, often it works in DVD players that don't support CD-R. -
Jhebert that was the info i was looking for (i hope)
xbox.aimx.net has a list of compatible media.
I do own the DVD playback kit, but I have tried several different mpg and vcd files with no success, but i'll try that trick you posted.
Simple. Rip DVDs to lossless format that will stream to PS3 and Xbox 360
By FuzzyReets in forum Video Streaming DownloadingReplies: 6Last Post: 2nd Sep 2010, 19:18 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
Ripping DVDs for Xbox 360 help
By mikemar in forum Media Center PC / MediaCentersReplies: 8Last Post: 20th Jul 2009, 19:59 -
Amazon.com: $80 Xbox 360 HD DVD player + 6 HD DVDs
By louv68 in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2008, 14:25 -
What's the Best Bitrate for Converting DVDs to .264 MP4 files for xbox 360?
By keyed in forum Video ConversionReplies: 1Last Post: 3rd Feb 2008, 03:04
it is an aditional $30
