As you can tell I have a very old cam corder, but it has done me well.
I've decided after a long break to get back into things.
I have no idea however how to get the footage from my 8mm tape to the pc so I can burn to disc.
Anyone out there got any ideas??? ( I am blonde, so make it simple, lol)
I have bought a firewire but discovered its no use to me, sao before i go buying anything else, I thought i'd better ask around.
Many thanks in advance.
J.xxxxxx
Results 1 to 30 of 39
Start with whatever outputs the cam uses. Being older, you are likely stuck with S-Video or composite video outputs only. In which case you will need a capture card in your PC. You then connect the video output of the cam to the video inputs of the capture card and capture(record) the video in real time.
Google is your Friend -
Something like this http://svp.co.uk/product/pinnacle_dazzle_dvd_recorder_4340 is going to be your cheapest and easiest option.
Many thanks will give this a bash!!!
I'm very blonde though so who knows if I can work it our lol....
Do i still need a capture card with this or will it be included, (which i doubt for the price) but unsure!!
Thanks folks.
J.xxxxx -
It is instead of a capture card. What is referred to as a capture card is usually just that, a card that fits inside your computer and can capture, this is an external capture device. It plugs into a USB port on your computer and you plug your camcorder into it. It even comes with software that isn't great but is fairly simple to use (although whether it is blonde proof or not I don't know, I could always give it to my daughter to find out....) and works.
Ok I got the dazzle thingymijig.....all plugged in but damn it, no cables....
have got the audio ones but no rca video cable or s-video cable!!!
so have got sound, but no bloomin picture lol. Aghhh!!
Have spent all day on it....kids starving, cat died of malnutrition.......etc etc
HELP!!!
Ok off to see where i can find another cable!!!!!!!!
CCD-TR411E is Hi8
A simple standalone DVD recorder is an alternate method.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
many thanks
I have no problems watching it through the tv but i wanted to start using my cam again and really wanted to be able to put it onto dvd, for keeps, kinda thing.
The dazzle instructions just say rca video cable or s-video cable but i cannot find either that has an end which will fit my cam
I'm totally lost (again).
After getting dazzle I've also found i cannot run the studio side of things as its says i need 512 physical memory, i only have 256. Another
So frustrated now!!!!
But thanks xxx -
Correction. I found a reference that says the CCD-TR411E is a Video8 camcorder.
In that case it would just have a yellow RCA connector for video and a white RCA connector for mono audio.Recommends: Kiva.org - Loans that change lives.
thats the fella!!!
Wonder why I'm not getting picture through then???
Thanks tho.
xxxx -
Connect Yellow on the camcorder to yellow on the Dazzle and white on the camcorder to white on the Dazzle. You'll only have mono audio but as that's all the camcorder recorded you can't expect beter than that. In the Dazzle software, tell it to use the Composite input. You don't need to worry about specific cables, a cable intended for audio will work just as well.
Connect up as above, put the camcorder in Player mode and press play. You should see picture and sound on your computer. -
but the white on the cam is black!!!! Its yellow and black on the cam and yellow and white on dazzle!!!
See my predicament lol???
I know, woman are a nightmare....stop shaking your head at me and laughing!!!!
Luv Jxxxx -
OK, so go yellow to yellow and black to white. Yellow is always video, stereo audio is sometimes red and white, sometimes red and black, mono audio can be either red, white or black (or just about any colour you choose except yellow!).
If you are in postcode ares NN, PE or NR, it might be easier if I call round and set the bugger up for you (they are my work areas)! -
Aw babe, thank you so much and if I was in those areas I would accept, but I'm in scotland. Freezing by the way! lol.
Unfortunately my dad has been taken to hospital so I've not much time at the moment.
I did try that but still cant get the picture, just the sound, but when i get a chance over the weekend i shall try your instructions once again and let you know what happens.
Thank you very very much. I shall be intouch soon.
Luv J.xxxx -
Just had a quick shot, couldn't wait, but that instant dvd recorder program i got with the dazzle just freezes all the time and wont let me do anything then just doesn't respond!!!!
Who said this was easy??? lol
Sorry for being a complete doughnut!
J.xxxxx -
Go here http://www.ulead.co.uk/dmf/runme.htm and download the 30 day free trial of DVD Moviefactory. My 19 year old (blonde) daughter mastered it in a few minutes and a friend who finds text messages too complicated uses it too. Not that I'm insinuating anything of course, but.......
Yes, Scotland has the crap weather at the moment, we've got 12 degrees, bright sunshine but freezing wind! -
Sorry not replied earlier, been at hospital to see daddy.
Of to the site now, will keep you posted.
Just because they can manage it, doesn't mean i can lol....be warned!!!
J x x x x -
Well Richard......guess what???
That never worked, lol.
I get to the capture video stage where you pick source etc, and it freezes as well, like the dazzle!!!!
Soooo frustrating, which you lived here lol.
Any suggestions?? lol......
Well I did warn you lol.....sorry!!
I love peterborough by the way, used to stop there every year on the way to the norfolk broads when i was a child!!!
Luv J.xxxx -
Ok tweaked about, suprised i'm still online to be honest lol.
jk!!
Ok this is what i got........
cannot start the capture graph.
capture failed.
the created file is sorrupt or unusable.
it will automatically be deleted.
at the side it says.......
free/total hard disc space
18.17GB/37.27GB
Give up for tonight, 3 hours is enough .
Best of luck!! lol
xxxxx -
had another try before i went off, and hey! I've got the picture !!!!
WAHEY!!!!!
But.........
No sound!!!!!!
messed with the settings but still nowt!!!
Please....can i have some more of your precious time Richard???? xmwahx
Luv J.xxxx -
WAHEY!!!!!
But.........
No sound!!!!!!
Luv J.xxxx -
ok losing the will here.........
cannot start recording comes up with the
capture failed.
so all i can do at present is watch the, "no sound video", but cannot save it or record it.............
xxx -
Sorry for not replying sooner, been in London all weekend. I've had the 'cannot start the capture graph' error before on othe Ulead software. If I remember right it's a common one with a simple fix. But..... I can't for the life of me remember what it was.
I'll have a look later and see if I can find it. It may be the same thing that was causing the Dazzle software to crash as well. -
Ah, just found it. It is caused by a DirectX error. For Windows XP, you need to have DirextX 9c installed. It may be that you've got an earlier version or that yours has got corrupted by something. Go to http://www.microsoft.com/downloads/details.aspx?FamilyId=4B1F5D0C-5E44-4864-93CD-464EF...displaylang=en or http://www.directx9soft.info/uk/ and download it.
If I remember right, you may need to install DirectX and then re-install the software. -
oh how glad was I when I saw your reply this morning, big smile on face.
And even bigger smile when i realised I wasn't the only one with this problem and I'm not completely thick!!! *debatable i suppose!*
I shall crack on with the six and let you know how i get on.
Hope you had a great weekend, I love london. Did you visit Hamleys??? My favourite store!!!
x x x x x -
ok heres this mornings run down lol.....
Downloaded the directx thingy.
Uninstalled pinnacle...
uninstalled movie factoy.
Reinstalled Pinnacle......got it working with sound, but picture was really jerky and it was like watchin a picture slide show.
Reinstalled movie factory.......same probs as before.
Is this impossible and your just not telling me lol.?
Although the smile is fading fast.....
Disaster!!!
xxxxxx -
Blimey, this is getting complicated. OK, so Pinnacle seemed to work but the picture was jerky. Did it record and was the recording jerky or was it just jerky when you were watching it while recording? The Dazzle is a USB device and ideally needs a USB2 connection. Is it plugged into a USB socket on the front or back of your computer? On some motherboards, the sockets on the back are USB2 and the ones on the front are USB1.1 so are slower. If this is the case you sometimes get a message saying that you have plugged a high speed USB device into a low speed socket (but not always). Are you running Windows XP SP2 (Go to Control Panel > System > Open and it should say Windows XP, Service Pack 2) as pre-SP2 didn't support USB2.
Alternatively, book yourself a holiday on the Broads and drop it in on your way by.....
It should all work. I've got an older generation Dazzle device that will work on a 1.5 GHz laptop. Usually this sort of thing is down to a problem with the setup of the computer itself that only become apparent when you ask it to work that bit harder. -
Ok, I have sp2, on windows xp.
I have a usb 2
Have just tryed to open the pinnacle again and its just freezing now.
If I didn''t have an auld man in the hospital I'd take you up on the visit, trust me, this is driving me so mad I'll need a holiday shortly!!!I cannot even get the frozen pinnacle window to close!!
It has to be simpler than this........
I thank you so very much for your time with this Richard....your a star!!
xxxxxxxxxx
Sony Handycam ccd-trv138 issues
By shashgo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Dec 2010, 12:27 -
Help with Sony CCD-TRV608 camcorder
By jrglenn12 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Mar 2010, 15:10 -
Sony ccd-tr360e to pc
By AntiBaltak in forum Capturing and VCRReplies: 3Last Post: 30th Nov 2009, 11:22 -
Sony camcorder CCD-TR705 vs CCD-TRV95
By younso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th Jul 2009, 16:32 -
Problem with Sony CCD TR77 Video8 Handycam
By wiseant in forum Capturing and VCRReplies: 3Last Post: 29th Oct 2007, 18:55
