Results 1 to 20 of 20
  1. After authoring elementary video stream (MPV) and compiling it - i played it in PowerDVD
    and the result was terrible!!!
    The video frame starts to leap from specific point till the end of the movie...
    i erased the movie and compiled it all over again and it didn't help,
    actually - it leaped again exactly from the same point it leaped at the first compilation!
    heres the log:
    *** DVD Aa2 Pro Verification Log ***
        12 - 18 - 2007 -- 13:41:9
    *   VMG Verification   *
    Number of VTS - 1
    Number of Menus: 1
    Menu 01 - Type - Dummy
    Number of imported VTS: 0
    *   VTS Verification   *
    <<< VTS Number 1 >>>
    Number of Titles: 1
    Title 01 - Type - ES or PES
    Segment 1, Video File C:\Program Files\DIKO\Temp\0 - ***censored.mpv
    	Frame Size: 544 X 480
    	Frame Rate 4   		[1--23.976, 2--24, 4--29.97, 3--25, 5--30]
    	Aspect Ratio: 43   	[43--4:3, 169--16:9]
    	MPEG Video Type: 2   	[1--MPEG 1, 2--MPEG 2]
    	Chroma: 1   		[1--4:2:0, 2--4:2:2, 3--4:4:4]
    	GOP 1, size - 9094
    	GOP 2, size - 9028
    	GOP 3, size - 8963
    Segment 1, Audio File E:\Video Edit\***censored.ac3
    	Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 320000
    Segment 1, Subtitle File E:\כתוביות\***censored.sp1
    Number of Menus: 3
    Menu 02 - Type - Still
    	nMenu cell count - 1
    	Menu Image File C:\Temp\55059360_tmp1.bmp
    	Picture size - 720 x 480
    	Menu Audio File - None
    	Menu Sub-Picture File C:\Temp\55059360_tmpsub1.bmp
    Menu 03 - Type - Motion
    	Menu Video File C:\Documents and Settings\צוריאל\My Documents\DVD Lab Videos\***censored.m2v
    	Frame size: 720 X 480
    	Frame rate 4   		[1--23.976, 2--24, 4--29.97, 3--25, 5--30]
    	GOP 1, size - 175028
    	GOP 2, size - 172125
    	GOP 3, size - 171792
    	Menu Sub-Picture File C:\Temp\55704552_tmpsub1.bmp
    *   Status Messages    *
    	Start building Video Title Set ( VTS )  ... - 2001
    	Title - 1
    	Start building VOB streams - 2210
    	Muxing elementary streams is in process ... - 2220
    	Initializing audio packets ... - 3005
    	Initializing AC3 (MOT) audio packet ... - 3030
    	Muxing is in process ... - 2300
    	Audio packetizing ends - 3025
    	Creating PGC for the title is in process ... - 2500
    	Creating dummy menu is in process ... - 2790
    	Creating still menu is in process ... - 2700
    	Start encoding bitmap ... - 2750
    	Reading bitmap is in process ... - 2740
    	[INFO] - No audio stream is provided - 3019
    	Encoding bitmap and building VOBU is in process ... - 2450
    	Creating motion menu is in process ... - 2600
    	Building VTS IFO stream is in process ... - 2800
    	Start building Video Manager (VMG) ... - 2005
    	Building VMG IFO stream is in process ... - 2850
    *** Post Verification ***
    No error was found in the post verification process
    Authoring is successfully completed - 3900
    Thanks In Advanced!!!
  2. Member dadrab's Avatar
    Mar 2006
    State of Denial, U.S.
    I'm not the end-all in DVDLabPro, nor am I the sharpest tool in the shed, but I have authored a good many discs sucessfully now in that application.
    Could you please restate your issue? I'm not sure what "leap from specific point till the end of the movie... " means. If you mean the movie stops and jumps to the end, I would suggest checking your connections and making sure you don't have a command at that particular spot that would auto jump to the end of the movie.
    I would also suggest you view the movie before you put it into the assets bin to make sure you have the whole thing to begin with.
    How did you arrive at your elementary streams? Did you let DVDLabPro demux for you?
    Was this something that you captured? How did that happen? What format?
    Was it something you encoded? How?
    Check your streams to make sure they're DVD compatible.
    Are you playing the video from the output folder on your hard disc? The reason I ask is if you have a bad burn on a disc, it can behave in this manner. If you see this problem when playing from the hard disc output folder, select the Connections tab in DLP and make sure there isn't something there that you didn't intend to be.
  4. Member driguy's Avatar
    Feb 2007
    I'm surprised DVDLab Pro let you compile...
    Your 1st VTS's video specs are 544 X 480, not DVD compliant as the rest of the project is. Not to be a jerk, but I would look at that first. Just a suggestion.
  5. Banned
    Jun 2007
    UNREACHABLE
    Certainly the problem of the OP is not in the non-standard resolution of their DVD-video.
  6. Thank you all for helping!
    Originally Posted by dadrab
    Could you please restate your issue? I'm not sure what "leap from specific point till the end of the movie... " means..
    it means that the movie's frame rotating/shaking till the end of it...
    i checked it before adding it to assets window - it worked great!
    How did you arrive at your elementary streams? Did you let DVDLabPro demux for you?.
    i created it myself with DIKO... it was AVI file...
    and its not the first nor the second time i use this method (AVI =>DIKO=> MPV =>DVD Lab Pro).
    Output folder... so it cant be bad burn...
    but like i said - i use the same method over and over with the same resolution...
    the elementary stream (MPV) works fine (played it with BSPlayer),
    thats why i don't get it...
    Thank you all again!
    We have a forum member from Australia called guns1inger. He is quite knowledgeable on DLP. Maybe when its daytime there he will have some helpful info for you.
  8. Member GeorgeW's Avatar
    Feb 2005
    I'd agree that the 544x480 is something to start looking into. Can you try to re-encode that to a valid NTSC resolution to see if it makes any difference?
    Regards,
    George
  9. Banned
    Jun 2007
    UNREACHABLE
    I have already created several "400/480/512/528/544/560/576/640 x 480/576"
    disks with DVD-lab PRO, and my LG has always played back them all without a problem.
  10. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you could try the dlp tool - re-write gop timecode. but i'd agree with the other guys. 544x480 is not a dvd res. 720x480, 704x480, 352x240 are your only choices. uncheck the properties/options/advanced box to allow non-dvd sizes, and don't use them.
  11. Banned
    Jun 2007
    UNREACHABLE
    You forgot to mention 352x480 :P
    @ GangstaRap : what is the opinion of your standalone player
  12. yes, i guess you'll right...
    i should try encode it again - but this time with DVD Res...
    i'll let you know if it's helped...
    the man quite knowledgeable on everything...
    GREAT man!
    thanks you all for your help!
  13. well...
    weird...
    i encoded the video again...
    this time to 704X480 resolution ant its running great!
    guess it was something to do with the video resolution or something...
    though its the first time it's happening...
    AND its played from my hard-disk...
    anyway...
    i couldn't solve it without your help...
    THANKS!
  14. Banned
    Jun 2007
    UNREACHABLE
    It still seems the real problem is in your PowerDVD ---
    and you simply found a way to by-pass it.
    If your standalone player is 100%-functional,
    but you don't use it anymore,
    could you please give it to me?
    I'm curious; did DLP give you a warning when you compiled the DVD when you were having the problem?
  16. SCDVD,
    for every 544 X 480 video i'm addin' to assets window i get the massage that warns me about not havin' DVD compliant resolution...
    but it also give me the choice to ignore this massage...
    my Pioneer can handle this resolution...
    maybe PowerDVD cant...
    You may want to try VLC. It's a very good player and it's free.
  18. SCDVD,
    can it play authored DVD files?
    All DVDs are authored by someone. If you are asking if VLC will play non compliant DVDs, that's a different question. With any player, there is always the risk of strange behavior if the DVD is not compliant with the DVD spec. You can get by with some things but there is no player that can deal with any type of non compliant DVD that you throw at it.
  20. Banned
    Jun 2007
    UNREACHABLE
    Software media players cannot be smarter than the people
    who create them. Indeed it requires a lot of IQ to program
    a video player for despising the MPEG-compliance only because
    the file container is a .VOB instead of a .MPG --- evidently, such
    pseudo-developers really believe the DVD-Forum idiots deserve to be
    very-well cocksucked.
