Is there a program that will convert MPEG's to AVI without making the file extremely large?
I have been using VirtualDub and it converts MPEG to AVI but it takes a 300MB MPEG file and makes it a 19GB AVI file. Not sure why or if there is a way to stop this.
Hi-
That's because you're not choosing and setting up a codec (Video->Compression). You're getting the AVI uncompressed. So, install (if not installed already) a common codec such as XviD or DivX and use one of them, or maybe let AutoGK do the whole thing for you.I have been using VirtualDub and it converts MPEG to AVI but it takes a 300MB MPEG file and makes it a 19GB AVI file.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
