I'm very new at all of this and I'm still having a lot of problems but thanks to this great site I'm actually making a lot of progress.
My question is can you edit a movie captured from a video camera using Virtual Dub & Huffy codec before it is converted using TPMGENC.
I want to add music, transitions and cut. I have tried using Easycd creator 5 Video impressions but it will only work once the clip is converted using tpmgenc which is ok but it looses quality once I save it because I think it re-converts if that makes any since.
I want to burn the finished product in VCD EASY because it works. It is the only software I have burnt a cd with so far that has produced a Cd that will work in my VCD Stand Alone Player.
Can any one suggest an editing program that will work with the applications I am using and has the editing features I am after?
You can download MovieXone from AIST. The software is free and it's basically a light version of their commercial products.
You can cut, edit, transform etc. etc. etc.
Render the edited video as DV .avi and then use TMPEG to convert the movie into VCD or SVCD etc.
Download under www.aist.com
Cheers
Pat -
Thanks for the advice. I've looked at the aist site and all looks good but I was unable to down load MovieXone they must be busy. I'm eager to do some editing can some one suggest any other programs I should try?
Converting and Editing AVCHD
By akosvfr in forum Newbie / General discussionsReplies: 0Last Post: 3rd Aug 2011, 05:08 -
Video converting/editing IRC?
By aple in forum Newbie / General discussionsReplies: 0Last Post: 12th Jul 2011, 18:36 -
Capturing and Editing/Converting
By eighteesix in forum MacReplies: 3Last Post: 26th Mar 2009, 12:20 -
Converting MTS for editing...
By Saibot in forum Video ConversionReplies: 1Last Post: 18th Feb 2009, 20:57 -
Using Blueray or HD , Converting or Editing
By Fary4u in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2007, 17:42
