i am trying to convert 12 hours of dvd's to mpeg1 format. i would like to get a program that will convert it as quick as possible but not lose any of the quality. i have tried a few programs and either they lock up or the audio is off. I can convert them in 2 hour portions but no less. and i know mpeg1 is old but that is what i need for the people to be able to use it in their program. Please help.
Not possible.Originally Posted by videogirl
Any conversion will lose quality. Converting to MPG-1 will lose quite a bit of quality.
If you are thinking of VCD MPG-1 format, that's 1150Kbps bitrate. Your original DVDs, if commercial, are probably closer to 8000 - 9000Kbps. That's quite a difference.
Most burned DVDs will be 6000Kbps or more if they have much quality to start with.
You could use VOB2MPEG to extract a MPEG-2 file from the VOBs, then re-encode to MPG-1 format. TMPGEnc encoder is free for that format use. But it's not fast, especially for 12 hours of video.
Even with a faster encoder, you may looking a quite a few hours of encoding, a lot more than 12 hours, unless you have a very fast CPU and lots of hard drive space. -
Use TmpgEncXpress
You'll have to use a high bitrate to keep the quality level high, though.
As redwudz mentioned, VCD qulity will not look as good as the original MPEG2
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Poor DVD quality: Computer screen recorded to DVD (mpeg1)
By MC123 in forum MacReplies: 6Last Post: 3rd Feb 2008, 16:33 -
question about how to author DVD from several mpeg1 files
By jimdagys in forum Newbie / General discussionsReplies: 11Last Post: 5th Jan 2008, 08:49 -
Mpeg1 to DVD, problems abound - help, please
By Neisse in forum Video ConversionReplies: 6Last Post: 8th Jul 2007, 18:23 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
