Anyone know what the longest running minidv battery is? Do they make any that last around 15 hours without turning your camera off.
i have one that lasts 6 hours of record time for a sony. it's huge, sticks way off the back, and weighs almost as much as the cam. 15 may be pushing it.
Depends on your make/model + what you do with it. If you use it in manual mode and don't zoom much you'll get more time than if you autofocus, zoom all the time etc.
You can get belts for multiple batteries that can hook up as one large one. That's the only way you'll get the time you need. Why not have multiple batteries and change them at the same time you change the tape? After all, you can't get a 15 hour tape! -
You know what you are right. Someone mentioned to me that you could record 15 hours of footage on a 1 gig memory card. No way, a minidv can eat up a gig in a few minutes.
July 22, 2009 the longest solar eclipse of the 21st century
By freebird73717 in forum Off topicReplies: 3Last Post: 23rd Jul 2009, 10:39 -
System Running Slow when running dvdshrink
By mn072065 in forum ComputerReplies: 7Last Post: 24th Mar 2009, 20:59 -
Longest Continuous Capture?
By quicksilverg4 in forum Capturing and VCRReplies: 9Last Post: 19th Apr 2008, 09:34 -
miniDV to hard drive to miniDV while preserving time and date?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 22:46 -
Longest portable video play
By Shaorin in forum Newbie / General discussionsReplies: 1Last Post: 21st Jul 2007, 00:21
