Hello,
I am trying to make a simple audio CD from a wav file to play in a common CD player which is no problem. The thing is I want to add an .avi file with a video to the same cd to play on a pc with WMP. How can I do this? If I burn as data in nero the audio file will not work in a player and if I cut to an audio cd putting in in the correct .cda format it will not let me add the avi file. Any suggestions would be appreciated.
Thanks,
But i'm sure the newer versions also have this feature.
EDIT:
Just an extra note, if you are making a cd that is to be playable in a standard cd player, you are not going to have much room for an avi or audio tracks on a cd-r if combining the two on a single cd-r.
AVI files refuse to be added
By johnbrigden in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 14th Jul 2010, 13:05 -
Added new drive, file transfer problem
By CapeKO in forum ComputerReplies: 9Last Post: 1st Sep 2008, 09:53 -
Can Audio Be added to DVD Menus?
By Scav2003 in forum Authoring (DVD)Replies: 2Last Post: 4th Apr 2008, 17:59 -
Subtitles not added during conversion of Pal to NTSC 2 avis with 2 sup file
By unity860 in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 3rd Apr 2008, 07:54 -
How to adjust the audio to be all the same in every video file added todvd?
By f-zer0 in forum AudioReplies: 5Last Post: 27th Feb 2008, 19:01
