Hi, I burned a disc with some data, and I left the disc open for multiple recordings. When I went back to record more data to the disc, the new data shows up fine, but the original data is gone. These are NOT RW discs. What could have happened? Is there any way to retrieve the lost data? Looking at the disc, it looks like the new data was added to the old, as there is now less "free space" appearing.
Thanks!
Burned with what? DVD recorder, burner with what software etc?
Read by what software? -
You didn't import the first session when you burned the second session. IsoBuster should be able to recover the first session.
There is only one "active" table of contents (TOC) on the disc. When you burn a second session the first TOC is marked invalid and a second TOC is written. If you want to retain the files from the first session you have to import the first TOC when you burn the second session.
Do Any Double Layer Disc Work With Panasonic DMR-EZ48V?
By cbehr91 in forum DVD & Blu-ray RecordersReplies: 13Last Post: 10th Jun 2010, 15:39 -
Burning Double Layer Disc
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2009, 08:22 -
How do I burn double layer disc with Nero 9
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2009, 05:13 -
ISO burned to disc,what next?
By When in forum Authoring (DVD)Replies: 7Last Post: 13th Jun 2008, 07:01 -
How to burn 8.3G iso movie file to dvd double layer disc?
By ibearzz in forum DVD RippingReplies: 12Last Post: 21st Oct 2007, 19:47
