I merge multiple avis with 123 audio video merger and use nero express to convert & burn the cd. when i put it in my dvd player i hear beeps while playing the disc.
my bro burned a video the same way as i did except he had a mpg video and didnt merge any together. It came out fine. The avi file didnt have any beeps when i play it on my pc. whats going on?
Without actually hearing the sound, it's hard to know exactly what you are hearing. I suspect you aren't actually hearing beeps but breaks in the audio stream where the files are connected to together or the audio stream wasn't properly converted and you are hearing digital after effects.
First, I would use a different tool for the conversion. Nero works for some things and doesn't for most and it's not a very good tool anyway. Try something like ConvertX2DVD. There are numerous others in the Tools section.Google is your Friend -
Its a squeeking kind of beep. Sometimes i get a few seconds with no beeps, other times i get 2 in 1 second. it also stalls/pause when it happens sometimes.
It happens throughout the video, not when two episodes are joined. I tried other ways to convert it, i still get the problem.
i tried reencoding it again with a different program. i got the same problem. -
I would still expect it to be the conversion process.
Another possibility could be cheap media or bad burning. I've burned audio cd's in the past using crap media that produced various playback issues including similar type sounds when playing the discs.
To troubleshoot, perform the conversion and burning of the disc in seperate steps. After the conversion is completed, playback the files of disc image and see if the problem exists. If it does, it's the conversion process. If it doesn't, then try burning. If it exists again in the final disc, then it is a media/burning issue.Google is your Friend -
hmm ok.
I have a way to merge the avi videos together, i'll skip this for now.
I know how to separate the audio from video using virtualdub, i'll try that.
What can i use to convert an avi and a wav (or mp3 or mpa) to a svcd?
and after i get this svcd how do i burn it?
i tried looking around, i cant find any tutorials to do the above, usually its to a dvd or bypass avi an wav conversion or something else. -
HOW TO: Convert, then choose avi to SVCD. You will get a list of guides and the tools used.
Keep in mind, however, that by changing the process and tools used likely won't help troubleshoot your conversion to DVD issue. If you want to experiment with different tools and procedues, experiment doing conversions to DVD.Google is your Friend
GOTSent, after conversion it leaves my .mp4's useless due to LOUD BEEPING
By Clifurd in forum Video ConversionReplies: 13Last Post: 16th Sep 2009, 04:01 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Computer shut ByItself, Surge Protector Beeping
By kerrex_2006 in forum ComputerReplies: 3Last Post: 8th Apr 2009, 02:23 -
Beeping on audio on Panasonic HVX200
By spandau in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2007, 22:29 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25
