sorry if i am in the wrong section . anyways i have a problem i have a family video of my brothers child hood i cant seem to play it nor convert it . its actually a wmv file i tried Gspot software but it came up with the Codec Status Undetermined plus showed me that i need a wmv3 codec so i downloaded and installed wmv3 codec but still gspot gives me the same Codec Status Undetermined . although i have klite ,media player and vlc player installed .i cant seem to understand the problem . hoping for some help thanks in advance!
I'm not sure GSpot handles WMVs properly, though. (I'm not on a system with GSpot and a WMV or two handy to test, at the moment, unfortunately.) You might also try running it through MediaInfo.
Assuming the WMV isn't corrupt, Vista's Windows Media Player should be able to play it without problem. The fact that you have K-Lite installed does raise a bit of concern, though - it could possibly have caused interference/problems with the Windows Media codecs already on the system.If cameras add ten pounds, why would people want to eat them? -
The OP's using Vista, which comes with WMP 11 installed.
I'm on the Vista system, now, myself, and I just ran a couple of WMVs through GSpot... both came up with "Codec Status Undetermined" for both audio and video codecs (different on both files) even though they play without any problems on WMP (which I don't use), or Media Player Classic (with ffdshow installed as well).If cameras add ten pounds, why would people want to eat them? -
Ooops! I should've checked before I postedThe OP's using Vista, which comes with WMP 11 installed.
Yea, all my WMV files show "Codec Status Undetermined" in GSpot.I just ran a couple of WMVs through GSpot... both came up with "Codec Status Undetermined" for both audio and video codecs
I have no experience with Vista or WMP11 so I can't be any help here but the mention of k-lite codec pack doesn't sound good.
After installing the latest Ffdshow to open and edit VC-1 files, I tried playing regular wmv files on the internet and MPC would not play them anymore unless I set libacodec to play them. I went back into decoder settings and set wmv7,8 and 9 to disabled and they now play without the help of Ffdshow. -
Yes, it's 2.70a.
Oh, I haven't had any problems using it under Vista, really. Or on Win98.
It's probably something to do with the WMV/ASF format more than a system problem, but I don't have any WMVs available on the Win98 system I'm on now to see if it does the same thing. :/
File wont play from memory stick but will from disc
By muay in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Jan 2011, 08:11 -
mkv wont play after merging .srt file to it
By vice86 in forum SubtitleReplies: 2Last Post: 27th Oct 2010, 23:41 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 10:41 -
help tvix 6500 wont play true hd how do i convert
By lodwales in forum Authoring (Blu-ray)Replies: 5Last Post: 21st Mar 2009, 08:45 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 14:58
