Hello Everyone,
I read a few articles on how to use mandvd and it seemed really cool. I was able to download, and install it. The problem is when I finish my conversion. I receieve the following log with errors. Does anyone have any suggestions on what I can do?
Code:--> Lancement de l'encodage des fichiers ------------------------------------------------------------ The selected video_out device is incompatible with this codec. Try adding the scale filter, e.g. -vf spp,scale instead of -vf spp. Limiting audio preload to 0.4s. Increasing audio density to 4. SwScaler: reducing / aligning filtersize 5 -> 4 SwScaler: reducing / aligning filtersize 5 -> 4 SwScaler: reducing / aligning filtersize 5 -> 4 SwScaler: reducing / aligning filtersize 5 -> 4 SwScaler: BICUBIC scaler, from yuv420p to yuv420p using MMX2 SwScaler: using 4-tap MMX scaler for horizontal luminance scaling SwScaler: using 4-tap MMX scaler for horizontal chrominance scaling SwScaler: using n-tap MMX scaler for vertical scaling (YV12 like) SwScaler: 352x240 -> 720x480 New_Face failed. Maybe the font path is wrong. Please supply the text font file (~/.mplayer/subfont.ttf). subtitle font: load_sub_face failed. 1 duplicate frame(s)! Skipping frame! Skipping frame! --> Lancement de la génération du menu ------------------------------------------------------------ 1920+0 records in 1920+0 records out 7680 bytes (7.7 kB) copied , 0.004293 seconds, 1.8 MB/s /home/user/mandvd//menu.sh: line 5: lame: command not found INFO: [ppmtoy4m] Command-line Parameters: INFO: [ppmtoy4m] framerate: 30000:1001 INFO: [ppmtoy4m] pixel aspect ratio: 10:11 INFO: [ppmtoy4m] pixel packing: RGB INFO: [ppmtoy4m] interlace: top-field-first (interleaved PPM input) INFO: [ppmtoy4m] starting frame: 0 INFO: [ppmtoy4m] # of frames: 1, or until input exhausted INFO: [ppmtoy4m] chroma subsampling: 4:2:0 MPEG-2 (horiz. cositing) jpegtopnm: WRITING PPM FILE INFO: [mpeg2enc] SETTING EXTENDED MMX for MOTION! INFO: [mpeg2enc] SETTING SSE and MMX for TRANSFORM! INFO: [mpeg2enc] SETTING EXTENDED MMX for PREDICTION! INFO: [ppmtoy4m] Output Stream parameters: INFO: [mpeg2enc] Selecting DVD output profile INFO: [mpeg2enc] Interlaced input - selecting interlaced encoding. INFO: [mpeg2enc] Encoding MPEG-2 video to genmenu.m2v INFO: [mpeg2enc] Horizontal size: 720 pel INFO: [mpeg2enc] Vertical size: 480 pel INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO) INFO: [mpeg2enc] Bitrate: 7500 KBit/s INFO: [mpeg2enc] Quality factor: 8 (Quantisation = 9) (1=best, 31=worst) INFO: [mpeg2enc] Field order for input: top-field-first INFO: [mpeg2enc] Sequence unlimited length INFO: [mpeg2enc] Search radius: 16 INFO: [mpeg2enc] DualPrime: no INFO: [ppmtoy4m] frame size: 720x480 pixels (518400 bytes) INFO: [ppmtoy4m] chroma: 4:2:0 MPEG-2 (horiz. cositing) INFO: [ppmtoy4m] frame rate: 30000/1001 fps (~29.970030) INFO: [ppmtoy4m] interlace: top-field-first INFO: [ppmtoy4m] sample aspect ratio: 10:11 INFO: [mpeg2enc] Using one-pass rate controller INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 18 INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC" INFO: [mpeg2enc] Progressive format frames = 0 INFO: [mpeg2enc] Using default unmodified quantization matrices INFO: [mpeg2enc] Buffering 39 frames INFO: [mpeg2enc] Signaling last frame = 0 INFO: [mpeg2enc] SETTING MMX and MMX for QUANTIZER! INFO: [mpeg2enc] NEW GOP INIT length 18 INFO: [mpeg2enc] Frame 0 0 I q=8.00 sum act=333.55365 INFO: [mpeg2enc] Sequence end inserted INFO: [mpeg2enc] Guesstimated final muxed size = 19559 INFO: [mplex] mplex version 1.8.0 (2.2.4 $Date: 2005/08/28 17:50:54 $) **ERROR: [mplex] Unable to open file silent.mpa for reading. DVDAuthor::spumux, version 0.6.11. Build options: gnugetopt magick iconv freetype fribidi Send bugs to <dvdauthor-users@lists.sourceforge.net> INFO: Locale=en_US.UTF-8 INFO: Converting filenames to UTF-8 STAT: 0:00:00.000 INFO: Picture survolee.png had 2 colors INFO: Picture cliquee.png had 2 colors INFO: Constructing blank img INFO: Pickbuttongroups, success with 1 groups, useimg=1 WARN: Read 0, expected 4 INFO: 0 subtitles added, 0 subtitles skipped, stream: 32, offset: -0.00 Statistics: - Processed 0 subtitles. - The longest display line had -1 characters. - The maximum number of displayed lines was 0. - The normal display height of the font arial.ttf was 0. - The bottom display height of the font arial.ttf was 0. - The biggest subtitle box had 0 bytes.
Results 1 to 1 of 1
Easy way to set DVD to play next file instead of returning to menu?
By Calidore in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2012, 19:04 -
Returning my Canon HF-R21 (But what should I replace it with?)
By Obtong in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2011, 14:10 -
Blockbuster returning from the Dead?
By 16mmJunkie in forum Latest Video NewsReplies: 53Last Post: 9th Apr 2011, 21:30 -
returning to the scene: need to transcode xvid/divx for psp
By cmwill84 in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2009, 04:10 -
I'm returning as a Moderator. tgpo is back!
By tgpo in forum Off topicReplies: 12Last Post: 2nd Apr 2009, 18:25
