I'm trying to burn AVI files to DVD in Nero vision in Nero 7 (also tryed trial verson of 8 ).
It get's about half way through converting the file then just closes and takes me back tot the menu where you decide what type of format you want (Audio, Video, Data ect). I tryed removing 7 and trying the new Nero 8, same problem, so I removed that and reinstalled Nero 7, this didn't fix the problem. I've Email Nero and am waiting for a responce, if one come's and fixes the problem I'll let you all know, and if it doesn't fix the problem I'll let you guys know as well just in case some one has the same ideas that Nero do, like I said, no error messages, nothings written to the DVD.
	What is your source video? Nero doesn't support all avis or it could be corrupt, I would just try convert to DVD with something else like DVD Flick, FAVC or ConvertXtoDVD and see if it works better.
	Are they free ware? it's in Xvid, it's done it to two different files, woun't there be an error message.? I'll trye copying something I know works tonight.
  HELP Burn using Nero Express doent work /but NERO VISION work fineBy STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
  Nero Vision 5 HelpBy luckyboym in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2008, 01:47
  need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10
  Nero Vision 5By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 14:45
  Chapters using Nero Vision?By aelfheah in forum Authoring (DVD)Replies: 4Last Post: 8th Jun 2007, 12:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
