Hi There, I just want to know a tool and any guides to making a 'sample' of a completed .avi file, and the sample output will be an avi with same specs as source (except the length of course) and about 1min long...
[size=9]Zhare Your Info Article Publisher
R5DVD.com Support Team
VLCPlayer.info - My Favourite Media Player -
Hehe, still trying to fulfill the "scene" requirements, I see. You'll want the sample from the AVI you made. You don't reencode a new one. So, you cut a one-minute piece of the encode you made. Open the AVI in VDubMod, answering "no" to the question about VBR audio. Set Video to Direct Stream Copy (up at the top, Video->Direct Stream Copy). Scroll to the beginning of the piece you want (hold down the Shift key for easier scrolling). Down at the bottom of VDubMod are a bunch of little buttons. To the right are 2 looking like little half-arrows. Hit the left-pointing one to mark the beginning. Scroll to the end of the section you want. Hit the right-pointing arrow. Now the section you want will be highlighted as a dark blue color. Go File->Save As, give it a name and that's it.
i use avi split which is a very cool tool and imo easier than V Dub for simply slicing out a bit of an avi file.
AviSplit (AVI/DivX video joiner, splitter and cutter)
http://www.bobyte.com/ -
thanks again manono, you obviously have been in my shoes once upon a time i see
well you know all the tricks and tips atleast. Yea, I was wondering about that thing abou VBR when fiddeling with VDubMod but other movies I have put into VDubMod have said the same thing, so i guess it just tries to make VBR -> CBR.
Cheerz[size=9]Zhare Your Info Article Publisher
hey manono, thanks for the info, and looking at the tutorials, ad downloaded the tool to cut the VOB and upload it for you to check out (thx heaps btw).
Hey, isnt progresive video better than interlaced video for the output, and would it be better to deinterlace a video if the source is interlaced... for my purposes? I am forcing Normal ITVC for hybrid in autoGK , but I am not sure if this is needed or not, do you have much experience in my kind of ripping, and what is involved, meaning what is the appropraite and best ways of doing it?
I just read something that said interlaced video is not good and should make it progressive, which is what i thought was the best way, what do you think on this situation?
will let you know when I have uploaded the sample vob for you to look at, jut working out the package you said to download, and reading the documents and how-tos to figure the best way to do this atm...
Thanks again for your help, I am getting there, and finally have a progressive output (as it was a progresssive source), with VBR / 128kbs and at 640 width, and came out at over 75% at 700mb, so lets see how this one comes back... after reading alot on this encoding method, and with your help, I hope this one passes.
And will get back to you soon with this interlaced question, and the blended frames dilema I faced with Lost and found, which i am still holding back on encoding until I find out how to remove the blended frames, so it is 'correctly done' - 3rd time lucky
Thanking you alot for all your help, and thanks to the Mod for explaining the rules
For XviD AVIs you pretty much have to make it progressive. When I said not to deinterlace movies, I meant not to deinterlace them using a deinterlacer. You unblend them if blended, realign the fields if phase-shifted, IVTC if telecined NTSC. One of the effects will be that the interlacing will go away, but the filters used aren't pure deinterlacers. Movies by definition are not interlaced.Hey, isnt progresive video better than interlaced video for the output,
Isn't this a PAL DVD? You don't IVTC a PAL DVD.I am forcing Normal ITVC for hybrid in autoGK
More than you'll ever know.do you have much experience in my kind of ripping
I can't guess what has to be done. Where's the sample?meaning what is the appropraite and best ways of doing it?
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Software to make sample of movie
By cyberlion in forum EditingReplies: 5Last Post: 7th Aug 2010, 07:32 -
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 11:24 -
Pls Help convert my 3gp file to mpg or avi
By Nanflexal in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 16:58 -
Can I make a AVI file smaller?
By baebbe in forum Newbie / General discussionsReplies: 7Last Post: 15th Aug 2008, 16:04
