  1. I need to convert them to DVD-compatible files, but first there's a problem.
    The files are tagged as:
    "Filename - RMVB.rmvb" and for some reason no player/converter recognises them.
    On top of that, I'm trying to rename them, and I don't have that option when I right click. When I right click, the only options I get are:
    Open
    Play in RealPlayer
    Add to RealPlayer 'Now Playing' list
    Burn CD in RealPlayer
    Open With..
    Send To
    I can't do anything with these files, can somebody please point me in the direction of some assistance?
    Thanks.
    USA
    Do you have 'Hide extensions for known file types' unchecked in 'Tools>Folder Options>Views'? That's in any folder menu. If not, you are not seeing the true extensions most times and you can't change them.
    I'm assuming you are using Real Alternative for the RMVB files? You can also use Real One Player, but I dislike it's 'phoning home' and trying to take over playback of most any files. Most other players can't handle RMVB files.
    And welcome to our forums.
  3. Yes it's unchecked, and yes I'm trying to use Real Alternative.
    I'll take a screen shot with it so you can see that it's stopping me.
    And thanks for the welcome.
  4. Mod Neophyte redwudz's Avatar
    USA
    The title may be too long and may have 'illegal' characters, like the brackets. You could also get rid of one of the '.Rmvb's, though that shouldn't matter. I would try shortening it.
    BTW, with a screen shot, click on the window you want to select, then use 'Alt + PrtScn' to get just that window. You can also set the 'Paint' screen size smaller than your screen shot to eliminate borders and you won't have anything but just the desired window. I also convert to JPEG.
    Or a more complete guide: https://forum.videohelp.com/topic271697.html
  5. Member Kayembee's Avatar
    Nov 2007
    RM files are tricky. You will need to have either the RealPlayer
    or Real Alternative installed, if you want to play them. With either of
    those installed, you won't need RealPlayer to actually play them,
    though - other players (e.g. Media Player Classic, mplayer, many more)
    will play them once the Realmedia software is installed.
    >Open
    >Play in RealPlayer
    >Open With..
    >Send To
    1) Left-click once on the file, to highlight it.
    2) Left-click again, or hit the F2 key, and you can edit the
    filename.
    Don't change the filename extension randomly. I've found that
    changing ".rmvb" to ".rm" can make 'em more compatible, but you
    shouldn't just rename to ".avi" or ".mpg" or something, as these
    identify other video formats. You need to actually convert the file to
    these formats, not just rename them.
    Converting rm files to DVD is possible, but a little tricky.
    Read up in the guides here about DVD formats. I'd use Avisynth plus an
    mpeg encoder, but that's a bit geeky. There's also a payware converter
    called Xilisoft Video Converter that can do this in a more
    straightforward manner. TMPGenc and other software should handle it too,
    once the Realmedia libraries are on your system. And if I recall
    correctly, TheFilmMachine can convert rmvb files directly into VOB (DVD)
    format. That might be the easiest way.
    Note that the typical rmvb file is heavily compressed, and
    converting 'em for DVD may not produce the video quality you'd hope for.
    My usual approach to this format is to leave 'em as-is, and just watch
    'em on the computer.
  6. I tried editing the file name, doing what you said. It still doesn't let me do it for some reason. Very odd. I remember having a similar problem, and being able to edit it after sometime, but for the life of me I can't remember how I did it. It's proving quite testing of my patience.
  7. Got it working. Now to convert it....
