I have a Nova Dv-P5133 dvd player and as i go to put a dvd in it says "no disc"everytime. The picture on my screen works and everything where it says the name brand of the dvd player"Nova" but it just won't start playing a dvd at all..Any help would be great cause i just don't want to go out and buy another dvd player if i can still fix this one. Thanks
I assume it does this with commercial discs beside burned discs? If it has the capability of playing CDs, like a VCD, try that. If it plays, you may have a failed DVD read laser.
Or it may have dirt on the lens. Try a lens cleaner. Other than that, the mechanism may be sticking. Most times, if it's something mechanical, it's not worth fixing. But if all else fails, try to get to the laser mechanism and see if it's free and clean.
It could also be a internal electrical problem, which definitely isn't worth fixing. This is what the mechanism looks like. This is from a CD player, but DVD players are very similar.
And welcome to our forums.
DVD subtitles aren't working in ANY media player in Windows 7
By Chair in forum SubtitleReplies: 2Last Post: 31st Aug 2009, 07:59 -
DVD Player not working Code 37
By rottenmarcel in forum DVD & Blu-ray WritersReplies: 4Last Post: 27th Nov 2008, 17:53 -
Zonefree DVD player into Panasonic Plasma not working
By Mark_MB750M in forum DVB / IPTVReplies: 11Last Post: 1st Sep 2008, 05:19 -
DVD player stopped working
By ishotlove in forum DVD & Blu-ray PlayersReplies: 7Last Post: 31st Jul 2007, 15:44 -
DVD player software not working.
By copiador in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2007, 21:09
