Dear Sirs
Is there any way to convert a dvd bought from Australia to play in a panasonic dvd player her in the U.S. I put the movie in my dvd player and the disc read" does not play in this region". What should a newbie like me do?
jadottey@aol.com
Find a newer DVD player that might play it, or use the following link that will teach you how to convert. It is a bit lengthy, but I know it works great.
https://forum.videohelp.com/topic300144.html -
If you have plenty of these disc, buy multi region DVD players that play NTSC & PAL.
This sounds like a region code problem. Many DVDs have a region code and players are not supposed to play them in other regions.
Seach https://www.videohelp.com/dvdhacks for a "Region code hack" to remove this "feature".
If no luck, you can do a backup of the DVD
https://www.videohelp.com/dvdbackup and remove the code and other annoyances (FBI tirades, etc).
If your player does not support PAL, that could be a separate problem, but try the region hacks first.
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
Video8 Conversion: Best trade-off for digital conversion ?
By ghl1 in forum Video ConversionReplies: 12Last Post: 6th Mar 2010, 18:36 -
DV vs DVD conversion
By asopher1 in forum Video ConversionReplies: 6Last Post: 11th May 2009, 12:12 -
HD DVD conversion help
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 2Last Post: 12th May 2008, 07:44 -
conversion from 2 avi files to a one DVD title in DVD flick
By netimen in forum Video ConversionReplies: 2Last Post: 30th Jun 2007, 09:06
