  1. Does anyone know if it is possible to extract only the Recode part of the Nero 8 program? I have Nero 8, as I bought it the other day but deleted it from my computer because I think version 6 works better. Is there a way for me to just get the Recode part of it and not the whole program of Nero 8?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Nero is an all-in-one package, it doesn't allow you to use seperate pieces. I also don't believe that you can install two different versions at the same time.
    Google is your Friend
  3. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    That's not true, I have both version 6 and version 7 installed on my laptop............both work fine.
  4. Originally Posted by racer-x
    Thanks for telling me that. I want to use version 6 and only the recode from my version 8.
    Is there anything I have to do to install my version 6, other than having it in a different folder and such?
