Hi,
I am converting some Final Cut Express (Apple Intermediate files in a Quicktime wrapper)
to H.264/mp4 for a playstation.
Everything works pretty good (Except ffmpegX seems not to be able to mux in audio for files over 2G)
but ...
I set the rate in the Video tab to 25000 kbit/s (which I think should be 25Mbps -- no ?)
Then I go to Options and set Qmin to 15 and Qmax to 30
Encode options are: Use CABC, constant bitrate, 2-pass encode, i4x4 analysis, Trellis, and Decode with Quicktime
On the PS3, I open the bitrate info and at certain points, the bitrates can exceed 200 Mbps! and frequently exceed 40 Mbps
Am I doing something wrong here ? The PS3 cannot decode at +200 Mbps so the video becomes very jerky in places.
Why so high? H.264 doesn't need the high bitrates that e.g. DV needs.Originally Posted by limeyx
For 1920x1080 (HD), 7282 kbps should be enough. For smaller frames (1280x720, 720x480, ...) the bitrate can be lower. Use the bitrate calculator to get a good value for your settings.
Empty audio files when converting MPEG2 with h.264 mencoder or h.264 x264
By doctormelodious in forum ffmpegX general discussionReplies: 3Last Post: 4th Jul 2010, 09:12 -
Xvid VS X264 At High Bitrates
By mohawkcr in forum Video ConversionReplies: 1Last Post: 4th May 2010, 17:18 -
Any Disc Player that handles high bitrates from HD conversion?
By EAO in forum Newbie / General discussionsReplies: 7Last Post: 27th Feb 2008, 15:38 -
Encore/Video Wizard incompatibility with high bitrates?
By moxiecat in forum EditingReplies: 2Last Post: 20th Sep 2007, 15:29 -
H.264: higher video bitrates than suggested image size not working?
By FiD31 in forum ffmpegX general discussionReplies: 7Last Post: 23rd Jun 2007, 11:49
